Calculate the tension in the string
In summary, the conversation discusses calculating tension in a string in different situations and using basic trigonometry to solve problems involving torque. The conversation also provides guidance on solving equations and understanding the concept of moment and pivot points. The conversation concludes with a discussion on how the point of application of a force can affect the calculations.
ssj
36
1. Calculate the tension in the string T in each of the following situations.
In all calculations ignore the mass of the beam.
http://img146.imageshack.us/img146/7291/43422126ru2.th.jpg
2. Moment=F X Perpendicular Distance and Basic Trigonometry
3.I have tried 200N X 0.5m=100 100/Cos30
Help is much apperchated.
I understand the left side of this equation: the clockwise torque due to the 200 N force. The right side should be the counter-clockwise torque due to the tension of the cable.
Correct this equation, rewriting the right hand side in terms of T (tension). Then solve for T.
I think i have found the solution by calculating the "opp" tan30 X 0.5 = 0.2886 from there onward we do 200 X 0.5= 100/0.2886 =346.5/cos 30 = 400 N
However now I am stuck on an similar equation of http://img374.imageshack.us/img374/3332/22917237wh9.th.jpg
Don't really understand what you did there with tangents and cosines. All you need is:
0.5*200 = 0.5*T*sin(30)
which gives you T = 400.
However now I am stuck on an similar equation of...
Solve it in the same way. The only difference is the moment arm associated with the 200 N force.
I strongly suggest you adopt a systematic approach, like the one I used.
But why would you use sine30 wouldn't that work out the "opp"?. Due to the fact the T is on the hypoteanus.
You want the component of T perpendicular to the beam, which in this case means [itex]T\sin {30}[/itex].
But why would T need to become perpendicular ? Also for question 2 how am I ment to work it out without the given length ?
Because you are finding the torque (moment) it generates about the pivot point. Do you understand the definition of moment?
The moment is the turning force right ?
You could call it that, yes.
Im stuck on the second question I posted because they haven't stated the length what do I do ?
You are given all the lengths you need. (The force is at the midpoint of the beam.)
So the length is the mid-point between 0 and 0.5 ? meaning its 0.25
That's correct. But realize that you don't need the length of the beam: You can just use L or L/2. (The actual length doesn't matter.)
But doesn't the formula state Motion=Force * perpendicular distance ? This would mean the formula is 200*L = L*T*sin30 correct ?
Sure. Notice that the length cancels from both sides of that equation.
So your left with 200/sin30= T meaning 400= T ?
Right, as I stated in post #4. (This is for your first problem.)
This is for the second problem though, wouldn't the Motion be different due to the force being applyed to the mid-point? I seem to of gotten T=400 in my previous post.
These calculations apply to the first problem.
For the second problem, the method is exactly the same: Set clockwise and counter-clockwise torques equal. Of course the torque exerted by the 200 N force is different in the second problem, since it's applied at the midpoint instead of at the end.
Right, so I am correct when 200*L=L*T*Sin30 the "L"'s cancel out leaving 200=T*Sin30
We then Divide sin30 on each side leaving 200/sin30=T meaning 400=T is this correct ?
You are correct for the first problem, but not if you are talking about the second problem. (In the second problem, the moment arm for the 200 N force is no longer L.)
What is it then in the second problem?
You tell me. That force is applied at the midpoint of the beam, so what do you think?
I think that it becomes 200*0.25=0.25*t*sin30 is this equation correct ? 0.25 because 0.5/2= 0.25 also now the center of gravity has changed.
Not exactly. The only thing that changed is the point of application of the 200 N force; the other force (the tension) is still applied at the same place.
Wouldnt this mean that the pivot is slightly more changing the angle as the force is closer to the motion.
The pivot isn't changing, but the distance to the pivot point is. (At least for the 200 N force.)
Alright so the perpendicular distance is changing its now at the mid point the half of 0.5 is 0.25 and due to the fact that the force has moved half way I assume the distance is now half as well thus making it 0.25.
Right. If the beam has length L, then that 200 N force is a distance of L/2 from the pivot.
  • #31
So the length L must be 0.5 and this means we must 0.5/2 because of L/2 correct?
  • #32
Right.
  • #33
Alright this means that the equation becomes 200*L/2=L/2*T*sin30 ?
  • #34
Nope. Why do you have L/2 on both sides of the equation? Realize that the equation as you've written it gives the same answer as you got for problem 1. Is that reasonable?
  • #35
I can't seem to work it out correctly the force is L/2 away from the pivot and in order to work out the tension I must do something must I make T perpendicular ?
