Calculate theoretical static pressure drop in moving fluid
The discussion focuses on calculating the theoretical static pressure drop in a moving fluid using an Arduino pressure sensor to measure depth. The user has successfully calculated dynamic pressure but seeks guidance on determining total pressure to find the difference. Suggestions include considering the orientation of the tube and the relationship between the tube shape and the pressure transducer. Visual aids were requested to clarify these concepts.
  • Understanding of fluid dynamics principles
  • Familiarity with Arduino pressure sensors
  • Knowledge of pressure measurement techniques
  • Basic concepts of dynamic and static pressure
  • Research the relationship between tube orientation and pressure measurements
  • Explore fluid dynamics equations for static and dynamic pressure calculations
  • Learn about pressure transducer specifications and their impact on readings
  • Investigate visualization tools for fluid flow and pressure distribution
This discussion is beneficial for engineers, hobbyists working with Arduino, and anyone interested in fluid dynamics and pressure measurement techniques.
frozenguy
Hi folks,
I have a pressure sensor working with arduino to measure depth. I want to calculate what I should see as a change in pressure if I move the tube horizontally under the surface of the water, keeping the tube opening parallel to the flow.
I have calculated the dynamic pressure but need to calculate the total pressure to take a difference.
Thank you!
I can maybe turn the tube 90 deg into the flow and then measure that pressure?
Could you provide a picture, perhaps? The shape of the tube and how the pressure transducer is related to it is not clear to me.
  • · Replies 26 ·
