Calculating 4 Integral: A Tan & Cos Theta Substitution
The discussion revolves around the calculation of the integral 4 ∫₀^(π/2) (cos²θ / (1 + cos²θ)²) dθ, exploring various substitution methods including u = tanθ and u = cos t. Participants express confusion regarding the appropriateness of these substitutions and their implications for the integral's evaluation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the potential of using u = tanθ as a substitution, questioning its effectiveness compared to u = cos t. There are considerations about how these substitutions affect the integral and the resulting expressions. Some participants express uncertainty about the transformations and derivatives involved.
The conversation is ongoing, with participants actively engaging in exploring different substitution methods and their consequences. There is no clear consensus, but some guidance has been offered regarding the transformations and the relationships between trigonometric functions.
Participants note the limited scope of trigonometric functions they have learned, which may influence their understanding of the problem. There are also references to potential confusion regarding the limits of integration and the behavior of the functions involved.
flybyme
how would one calculate 4 \int_0^{\frac{\pi}{2}} \frac{\cos^2 \theta}{(1 + \cos^2 \theta)^2} d \theta?
someone suggested a u = \tan \theta substitution, but i don't understand why and how this would help me. couldn't i just use u = \cos t?
Divide top and bottom by \cos^4\theta.
The function becomes \frac{\sec^2\theta}{(\sec^2\theta+1)^2}
Does that make u=\tan\theta looks like a good move?
u = cos t is probably a bad move, because du = -sin t dt and the sin t doesn't cancel with anything.
the only trig functions we learn here are tan, cos and sin, so I'm not really sure... :)
wouldn't i get du = -sin t dt = -sqrt(1 - cos^2 t) = -sqrt(1 - u^2) dt?
because then the integral should translate to -4 \int_1^0 \frac{u^2}{ (u^2+1)(1-u^2)^{1/2} } du, or am i wrong?
I agree with what you had in the last post, except, wouldn't it be (1+u^2)^2 in the denominator? Anyway, now what?
yeah, I've never understood why that is so...
what is the derivative of \tan \theta?
also do you know 1+\tan^2\theta =\sec^2\theta?
I edited my post just a little too late... isn't it (u^2 + 1)^2 in the denominator?
oops. yeah, that's right.
no, i didn't know that. :)
so i would get 4 \int_0^{\pi/2} \frac{\sec^2 \theta}{(\sec^2 \theta + 1)^2} d \theta = 4 \int_0^{\pi/2} \frac{\tan^2 \theta + 1}{(\tan^2 \theta + 2)^2} d \theta = 4 \int_0^{\Omega} \frac{u^2 + 1}{(u^2 + 2)^2(u^2 + 1)} du = 4 \int_0^{\Omega} \frac{du}{(u^2 + 2)^2}
as u = \tan \theta and du = (1 + \tan^2 \theta) d \theta = (1 + u^2) d \theta.
does that seem correct? I'm unsure on what \Omega would be though, as \tan \pi/2 = \infty
Ahh Nope, \int \frac{\sec^2\theta}{(\sec^2\theta+1)^2} d\theta becomes \int \frac{1}{u^2} du when u = tan theta, because the derivative of tan theta is (sec theta)^2.
In case you don't know Sec x = 1/(cos x) by definition.
Oops... you mean \int \frac{1}{(u^2+2)^2} du
1 + tan^2 x = sec^2 x
NOT 1 + sec^x = tan^2 x !
(And even if that was true, it would have been u^4 not u^2)
Sorry about that, your right of course AlephZero.
\int_{0}^{\frac{\pi }{2}}\frac{\cos ^{2}x}{\left( 1+\cos ^{2}x\right) ^{2}}dx=\allowbreak \int_{0}^{\infty }\frac{1}{\left( 1+p^{2}\right) ^{2}\left( 1+\frac{1}{1+p^{2}}\right) ^{2}}\,dp=\int_{0}^{\infty }\frac{1}{\left( 2+p^{2}\right) ^{2}}\,dp\allowbreak
=\allowbreak \int_{0}^{\frac{1}{2}\pi }\frac{\sqrt{2}}{4+4\tan ^{2}q}\,dq=\frac{\sqrt{2}}{4}\int_{0}^{\frac{1}{2}\pi }\cos ^{2}q \ {} \ dq=\frac{\sqrt{2}}{4}\frac{\pi }{4}=\frac{\pi\sqrt{2}}{16}
Would I be the only person to be a tiny bit confused as to what exactly dexter did ...
Would it help if you knew that \tan x=p and p=\sqrt{2}\tan q ?
Ahh yup it did :D
  • · Replies 19 ·
