Calculating Acceleration of a Car After Braking
  • Thread starter Thread starter IDespisePhysics
    Acceleration
The problem involves calculating the acceleration of a car that comes to a stop after braking, with initial conditions provided such as speed and distance. The subject area is kinematics.
  • Exploratory, Assumption checking
  • The original poster attempts to apply the kinematic equation vf^2=vi^2+2ax but questions the correctness of their givens and whether unit conversion is necessary.
Some participants suggest that unit conversion is an important first step, indicating a productive direction in the discussion. The original poster expresses confusion regarding their calculations and the expected answer.
The original poster is working within the constraints of a homework assignment and is unsure about the application of kinematic equations without time as a variable.
IDespisePhysics
A car is traveling at 95 km/hr. The driver steps on the brakes and the car comes to a stop in 60 meters. What is the car's acceleration?
My issue might be which formula is correct but, I believe I would use, vf^2=vi^2+2ax
Every time I begin any problem I write down the givens.
d= 60 meters
Vi= 95 km/hr
Vf= 0 m/s
Are my givens wrong? If not, I've continued to plug it in into the problem above. I assume I'm using Kinematics and since the other equations require 't' or time, I don't believe I use those equations for this problem. As I plug the givens into the equation above, the math doesn't add up to the answer my teacher had said it was; which is -5.81m/s^2.
Would I have to convert the 95 km/hr?
That is one of your first steps to convert it out to get similar units.
Thank you! I got the answer now! :D
Happy to help :-)
  • · Replies 17 ·
