Calculating acceleration - Quick question
  • Thread starter Thread starter nukeman
    Acceleration
The discussion revolves around calculating the acceleration of a system involving a crane lifting two blocks with a combined weight of 110 kg and a lifting force of 1500 N. Participants are exploring the application of Newton's second law in this context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relevant equations, particularly Newton's second law, and question the necessity of a time variable for calculating acceleration. There is also exploration of how to calculate tension between the blocks and the implications of weight versus mass.
The discussion is active with various interpretations being explored. Some participants confirm approaches to calculating acceleration, while others raise questions about the role of gravitational force and the definitions of weight and mass. Guidance on using force diagrams is also suggested.
Participants are considering the effects of gravity on the system, questioning the initial assumptions about forces acting on the blocks. There is a lack of consensus on the correct approach to account for these forces in the calculations.
nukeman
Calculating acceleration - Quick question!
A crane if lifting 2 blocks connected to each other. both blocks weight a total of 110 kg - the crane is lifting with a force of 1500 N.
What is the acceleration? What formula do I use? I thought I needed a time variable to calculate acceleration?
Thanks!
Hi nukeman, it would help you to write down relevant equations. Ignoring the detail, you have a force acting on a mass, Newtons second law will help you here.
Cheers
So would it be acceleration = Fnet / mass?
So, 1500 / 110 ? or making converting the KG to N,
1500 / 1079 = 1.39 ??
can anyone confirm my answers for me? :)
And, if I want to get the tension between the 2 blocks, I treat the bottom block as the system, and apply Newtons 2nd law to it?
So, the bottom block is 50kg, and my (hopefully correct) acceleration as in the post above is 1.39,
tension would be 50kg / 1.39 to give me 35.97 N??
Hi, for the first question:
Yes you are correct
[itex]F_{net}=m a \Rightarrow a=\frac{F_{net}}{m}[/itex]
Okay so the mass is 110kg, and the total force is 1500N.
I do not understand what you mean by "converting" from Kg to N: Kg are units of mass, and N (Newtons) are units of Force, if it helps acceleration has units [itex]m/s^2[/itex].
So the correct value should be 1500/110= 13.6 m/s^2
For the second part I am not sure exactly what you mean, a force diagram will confirm the tension between the blocks.
Isn't this "crane ... lifting" here on the Earth? So you need to account for the force of gravity as well.
"weight" generally means mass*gravity. Otherwise, they would have said "mass". So, the net force on the blocks should be weight (mass * gravity) and the force on the other side (the crane).
Won't one of these forces overcome the other? If so, which one? This will give you a net force (mass * acceleration). You know the mass already, the acceleration should be easy to get using algebra.
10K
  • · Replies 47 ·
  • · Replies 38 ·
