Calculating Angular Deflection in a Welded Steel Bracket
The discussion revolves around calculating angular deflection in a welded steel bracket subjected to a force. Participants explore the relationship between the applied force, the geometry of the bracket, and the resulting deflections, including both angular and linear components. The conversation includes attempts to apply beam theory and references to tables for angular deflection.
  • Homework-related
  • One participant expresses uncertainty about how to find the angular deflection at the joint between the beam and the bracket.
  • Another suggests applying macroscopic conditions to determine moments and reactions as functions of the applied force and geometry.
  • There are references to using tables for calculating rotation angles at specific points, as well as using calculus of beam theory.
  • One participant questions the necessity of angular deflection for computing maximum deflection of the cantilever beam.
  • Another participant provides calculations for moments and reactions, but expresses uncertainty about how to use these values to find angular deflection.
  • One participant corrects a previous calculation regarding reactions and shares a calculated slope at the pivot point.
  • Deflections due to bending and bracket deformation are reported, leading to a total deflection calculation.
  • One participant emphasizes the general concept of approaching the problem rather than detailed calculations.
Participants exhibit a mix of agreement on the general approach to the problem but express differing opinions on the necessity and method for calculating angular deflection. The discussion remains unresolved regarding the best approach to find angular deflection and its relevance to the overall deflection calculation.
Some participants reference tables for angular deflection, but there is uncertainty about their availability and applicability. The discussion includes various assumptions about the geometry and loading conditions that are not fully detailed.
hatchelhoff
The Figure shows a welded steel bracket loaded by a force F = 5 kN.
[/B]
I know that the total deflection is the deflection of the beam due to F. And I also need to take into account the angular deflection at the joint between the beam and the bracket.
Im not sure how to find the angular deflection at the joint between the beam and the bracket.[/B]
You need to apply the macroscopic conditions, to determine MB and Rx as a function of F and the geometry.
since you are apparently allowed to use tables, look it up in a table that gives the rotation angle at the midpoint of the end plate, using the moment at the end of the cantilever as the applied couple at that point. Otherwise , use the calculus of beam theory.
MB = F*Distance = 5KN*410 mm = 2050 NM
R1 = R2 = MB/L = 2050NM/0.41M = 5000 N
Im not sure how to use these values to find the angular deflection.
I can't seem to find any such table. Can you point me int the right direction.
What do you mean by angular deflection? The rotation in Radians ?
I'm not too sure why you would need this value to compute the maximum deflection of the cantilever beam.
Can you please elaborate.
So you have MB. From the solution to the second problem, you can get the initial slope. You multiply that by the length of the beam to get the additional dip at the far end.
Ask and it shall be given unto thee, seek and ye shall find. Merry Christmas.
http://virtual.cvut.cz/beams/
Table 2 fig 8. Then follow Mr. Miller's last post.
CivilSigma I do mean the rotation in radans. In need this because the force F causes a deflection in the beam, but it also causes a deformation of the upright bracket which causes an additional dip at the far end.
PhanthomJay Merry christmas to you also. Thanks for your link.
Chestermiller I made an error in my previous post . I should have said that R1 = R2 = MB/L = 2050NM/0.3M = 6833.3 N
I have now calculated the slope at the pivot point to be 0.00669 radans
I have found the deflection of the beam due to bending to be 2.66 mm.
I have found the deflection of the beam due to the deformation of the bracket to be 2.74 mm.
this gives me a total deflection of 5.4 mm
I don't want to have to go through this entire problem and do the detailed calculations. My goal was just to point out the general concept of how to approach this problem. I assume you understood the concept. The rest was up to you. If you have questions about the general concept, I will be glad to address them.
Thanks I understood the concept, and I have no questions.
  • · Replies 17 ·
13K
