Calculating Angular Velocity and Time for Insect on Rotating Rod
43 replies · 7K views · last reply
Tiny tim...Which equations?
Do you mean you can't read the symbols below?
(if you can, just copy one and paste it :wink:)
Moderator's note: Moving to Intro Physics, since this is more about solving a particular problem than about broader conceptual issues.
M writing thru my cell..Its not allowing me to click on those letters..I can just c them
The equation which relates the speed V to the angular velocity ω,
and the τ = ωdI/dt equation
(with all the numbers, please :wink:).
I wrote it..We are just given Length of rod (L)in numbers which is 1.8 m..And i wrote already that ¥(angular velocity)=12V/7L..We have to calculate V in nos..
Tim..Torque is variable..We know change in angular momentum ..What can we do?
Call the position of the insect x, and the angle θ, and find the moment of inertia as a function of x, and the torque as a function of x and θ. :smile:
I guess u haven't read my earliear post..Torque varies as Mgx cos§ where x is insect's distance from centre and § is angle rotated by rod..Initial moment of inertia of rod +insect is 7MLL/12 AND when rod is vertical is MLL/3..How to calculate V in numbers?
hmm … that can't be right … 1/3 < 7/12, but the moment of inertia should be increasing.
If L is the length AB of the whole rod, then I for the rod is 1/12 ML2, to which you have to add I for the insect for L/4 ≤ x ≤ L/2. :smile:
Oh..Pardon..Its 7MLL/48 Instead of 7MLL/12..Sorry..But what can we do to calculate V?
That's better! :wink:
ok, then, as you said …
Now use τ = 12V/7L dI/dt. :smile:
Its a function of both x and § as stated earlier..How can we find V in numerals by using that!
