Calculating Capacitance of a Parallel Plate Capacitor Using Integration
  • Thread starter Thread starter sankalpmittal
    Capacitor
8 replies · 3K views
sankalpmittal
See the image:
http://postimg.org/image/q550yqqd1/
Left click to enlarge...
For a parallel plate capacitor, Capacitance C=KεoA/d
A is area of plate and d is distance between the two plates..
I do not know how to approach. I divided the capacitor along the diagonal into two halves. For the first half,
dC1 = K1εodA/dl
I took a strip of edge dx and length "l" perpendicular to the capacitor. Area of that strip= (x+dx)2-x2=2xdx..
dA=2xdx
Hence,
dC1 = 2K1εoxdx/dl
Now taking an angle θ, tanθ=d/a= (d-l)/(a-x)...
Am I going in the right direction ?
Please help !
Thanks in advance...
:smile:
I can't clearly picture how you're dividing up the device. In my mind's eye I can see taking vertical slices of width dx across the image. At some horizontal position x, a slice will effectively consist of two capacitors in series, one with dielectric K1, the other with dielectric K2. "Plate" area is given by a*dx, and "plate" separation for each capacitor can be determined with a bit of geometry.
Ok, So I have a differential form,
dC2=K2εoadx/distance, as per the hint you gave. I also understand that the two capacitors are in series. So what should I replace K with ?
And about geometry... I took angle θ between diagonal and an edge. Then,
tanθ = d/a = y/x = (d-y)/(a-x)
where, the capacitor with dielectric constant K2 is positioned at distance x and its distance from the one edge(horizontal) to the boundary of second capacitor.
Am I on the right track ? Thanks..
You don't replace K, rather you need to find expressions for the two capacitors in terms of their individual K's and geometry, then combine them in series to yield a net capacitance for that "slice". The slices are all in parallel...
I believe so... can you write expressions for the two capacitances of a slice?
gneill,
As per the image you gave,
dC1 = K1εoadx/d1
dC2= K2εoadx/d2
Correct ?
Now dC=dC1*dC2/(dC2+dC1) ?
sankalpmittal said:
gneill,
dC1 = K1εoadx/d1
dC2= K2εoadx/d2
Correct ?
Right. You'll want to express d1 and d2 in terms of some common variable over which you can integrate.
Ok, so replacing d2=d-d1,
dC1 = K1εoadx/d1
dC2= K2εoadx/(d-d1)
Now, dC=dC1*dC2/(dC2+dC1)
dC=K1K2εoadx/{K1(d-d1)+K2d1}
Now to what limit shall I integrate this expression over ? Looks like I will have to eliminate d1.
By geometry, I got,
d(a-x)/a = d1
Correct ?
P.S. d is distance between plates as given. dC is small capacitance. dx is small distance between slices as per your image. (Thanks.)
By geometry, I got,
d(a-x)/a = d1
Correct ?
Sure. So you're integrating w.r.t. x. You should be able to see from the diagram the limits for x.
Thanks a lot gneill ! :smile:
I integrated the expression in limits of x from zero to "a" and got the correct answer ! Thanks once again.
