Calculating Cd and Crr coefficient experimentally
  • Context: Graduate
  • Thread starter Thread starter jumpjack
    Coefficient
56 replies · 9K views
jumpjack
On this site I found how to calculate Cd and Crr coefficient from experimantal data:
http://www.instructables.com/id/Measure-the-drag-coefficient-of-your-car/
I am trying to implement it in a web page and in a smartphone application, so I must "replace" Excel Solver by an algorithm, but I'm very in trouble.
I figured out how to calculate coefficients of fitting polynomial, so I now have the equation which approximates the speed curve, in form of y = ax^2+bx+c
But now how do I correlate this equation to real data to obtain Cd and Crr?
The excel sheet relies on this formula:
v1 = v0 - a*t
where:
a = F/m
and
F = air drag + roll friction
air drag = 0.5 * r *A * Cd * v^2
roll friction = m * g * Crr
so I think it is:
v1 = v0 - 0.5 * r * A * Cd * v0^2 / m - g * Crr
if this is correct, I can "zip" to:
v1 = v0 + K v0^2 + H
and
K v0^2 + H = v1-v0
My idea is to use the next sample to build an equation couple which I can solve for K and H, and get Cd and Crr from them... but it looks like it does not work, what am I doing wrong?
K v0^2 + H = v1-v0
K v1^2 + H = v2-v1
on Phys.org
The equation of motion is ##\dot v = a (1 + \alpha^2 v^2) ##, where the dot means differentiation w.r.t. time, and ##a## and ##\alpha## are obtained from the constants of the problem. This equation can be integrated: $$
\int\limits_{v_i}^{v_f} {dv \over 1 + \alpha^2 v^2} = aT = \frac 1 \alpha \int\limits_{\alpha v_i}^{\alpha v_f} {d u \over 1 + u^2} = \frac 1 \alpha (\arctan \alpha v_f - \arctan \alpha v_i)
$$ where the i and f subscripts mean "initial" and "final", respectively, and ##T## is the time between them. We can further rewrite that as $$ a \alpha T - \arctan \alpha v_f + \arctan \alpha v_i = 0 $$ Now assume you have made ##N## measurements of ##v_{in}, v_{fn}, T_n##, where ##n## goes from 1 to ##N##, inclusive. For all those measurements you should have, in theory, the above equation exactly right. But it won't be exactly right, because your measurements are not infinitely precise, and the equation of motion is not exactly exactly right to begin with (it is a model). So instead of the zero on the right hand side you will get some error: $$ a \alpha T_n - \arctan \alpha v_{nf} + \arctan \alpha v_{ni} = \epsilon_n $$ Now you can square all those errors, sum them, and find ##a## and ##\alpha## that minimise the sum: $$ \sum\limits_{n = 1}^N \left[ a \alpha T_n - \arctan \alpha v_{nf} + \arctan \alpha v_{ni}\right]^2 \to \min $$ Once they are found, you will obtain your coefficients from them.
voko said:
and find ##a## and ##\alpha## that minimise the sum:.
I found this "suggestion" in several sources, but no examples at all, so I don't understand how to proceed!
Is there a "minimisation algorithm" somewhere? Or should I use "try&fail" method?
I do not know whether there is such a thing. Anyway, for the mobile application there are C/C#/Java libraries, so you should be all set. For a web page, you can run the computation server side and use whatever library that works for you.
I found this version for VBA:
Code:
Attribute VB_Name = "Lebenber_Marquart"
Option Explicit
Option Base 1
Sub LMNoLinearFit(x() As Double, y() As Double, c() As Double, ch2 As Double, Niter As Long, Optional Itmax As Long = 10000)
' Rutina para calcular los valores de ajuste por minimos cuadrados a un modelo Fun(x)
' mediante el algoritmo de Lebenberg-Marquart
' Los valores de arranque son c
' ver. 14.04.2006 by Luis Isaac Ramos Garcia and Foxes Team
' Bibliografia
' Numerical Recipies in Fortran77; W.H. Press, et al.; Cambridge U. Press
Dim i As Integer, k As Integer, kmax As Integer
Dim Mcoef() As Double, det As Double, tpc() As Double
Dim Diffc() As Double       ' Vector de diferecias entre antiguos c y nuevos
Dim delta As Double         ' Valor delta de algoritmo Levenberg-Marquardt
Dim tdelta As Double        ' relative increment
Dim mu As Double            ' reduction/amplification quadratic error
Dim ch20 As Double          ' quadratic error previous step
Dim delta0 As Double        ' increment previous step
Dim tol As Double           ' machine tolerance
Dim fact As Double          ' step factor
    ReDim Diffc(UBound(c) - LBound(c) + 1), tpc(LBound(c) To UBound(c))
    delta = 0.001  '0.1%
    k = 0
    Niter = 0
    fact = 10
    tol = 2 * 10 ^ -16
    kmax = Itmax / 4
    ch20 = chi2(x, y, c)
    Do While k < kmax And Niter < Itmax
        Call CalculateMcoef(x, y, c, Mcoef, delta)
        Call SolveLS(Mcoef, Diffc, det)
        For i = LBound(c) To UBound(c)
            tpc(i) = c(i) + Diffc(i - LBound(c) + 1)
        Next
        ch2 = chi2(x, y, tpc)
        If ch2 > tol Then mu = ch2 / ch20
        tdelta = (ch2 - ch20)
        If ch2 > tol Then tdelta = tdelta / ch2
        'DEBUG <<<<<<<<<<<<<<
'        Debug.Print Niter, delta, fact
        'DEBUG <<<<<<<<<<<<<<<<<<
        If mu > 10 Then
            delta = delta * fact
        Else
            If Abs(tdelta) < 0.001 Then k = k + 1
            delta = delta / fact
                c(i) = tpc(i)   'update new point
            Next i
            ch20 = ch2
        End If
        'check delta oscillation
        If Niter Mod 4 = 0 Then
            If delta0 = delta Then
                fact = 2  'relaxed step
            Else
                fact = 10 'fast step
            End If
            delta0 = delta
        End If
        Niter = Niter + 1
    Loop
    ch2 = chi2(x, y, c)  'best approximation
End Sub
Private Function chi2(x() As Double, y() As Double, c() As Double) As Double
Dim i As Integer, f() As Double
    Funct f, c, x       'take all function values
    chi2 = 0
    For i = LBound(x) To UBound(x)
        chi2 = chi2 + (y(i) - f(i)) ^ 2
    Next
End Function
Sub CalculateMcoef(x() As Double, y() As Double, c() As Double, Mcoef() As Double, delta As Double)
' Rutina para calcular los coeficintes de la matriz asociada al ajuste por minimos cuadrados para
' un modelo Fun(x) mediante el algoritmo de Lebenberg-Marquart
' Dfun es la rutina que calcula el vector gradiente
Dim i As Integer, l As Integer, k As Integer
Dim dv() As Double                             ' Vector gradiente de la funcion de ajuste
Dim temp As Double
Dim f() As Double
    ReDim Mcoef(UBound(c) - LBound(c) + 1, UBound(c) - LBound(c) + 2)
    DFunct dv, c, x     'take all derivatives values
    For i = 1 To UBound(x) - LBound(x) + 1
        For k = 1 To UBound(c) - LBound(c) + 1
            Mcoef(k, UBound(c) - LBound(c) + 2) = (y(i) - f(i)) * dv(i, k) + Mcoef(k, UBound(c) - LBound(c) + 2)
            For l = k To UBound(c) - LBound(c) + 1
                    Mcoef(k, l) = dv(i, k) * dv(i, l) + Mcoef(k, l)
            Next
        Next
    Next
    For k = 2 To UBound(c) - LBound(c) + 1
        For l = 1 To k - 1
            Mcoef(k, l) = Mcoef(l, k)
        Next
    Next
    For i = 1 To UBound(c) - LBound(c) + 1              'Algoritmo Marquart
        Mcoef(i, i) = Mcoef(i, i) * (1 + delta)
    Next
End Sub
http://digilander.libero.it/foxes/optimiz/Optimiz1.htm
Unfortunately it's poorly commented.
As far as i can understand, it requires a function in explicit form (Y=ax^2+bx+c), which i do not have. Is this source suitable for my task? if so, how do i put y1=y0 + K y0^2 + H in this code?!?
But... do I actually need to implement the algorithm??
I already found the best-fit equation for my data in form y=ax^2+bx+c , so the least square minimisation is already performed... or not?
Maybe I've just to figure out how to express (1) y1 = y0 + H y0^2 + H in (2) y=ax^2+bx+c form? Or I could get y0 and y1 from y=ax^2+bx+c equation which I already found, and obtain (1) with known values for y1 and y0. Then I could do the same for y2 and y1, and so I would have to equations and two unknown terms...
You need to make an effort and understand what I wrote in #2. The function to minimise, in terms of the page you referenced (see example 2), is $$ f(x_1, x_2, c_1, c_2) = \frac 1 {c_1 c_2} \left[ \arctan c_1 x_1 - \arctan c_1 x_2 \right] $$ where ##x_1 = v_i, x_2 = v_2, c_1 = \alpha, c_2 = a, y = T ##.
If your objective is to produce some numbers, however bogus, maybe yes.
If your objective is to produce numbers that approximate the coefficients, then definitely not.
The problem is that when you take measurements seconds apart - and especially 10 seconds apart as in the spreadsheet - the difference scheme approximation employed there fails miserably, because your time steps (leaps!) are just too wide. You need subsecond time resolution to get anywhere near decent approximation. And you cannot get that, plain and simple.
So you have to use a more accurate approximation of motion between the rare moments when you get a velocity fix, and you need more than two measurements because mobile phone GPS/accelerometer readings are not known for exceeding accuracy.
I thought this was the function to minimize:
Anyway I don't know which are the steps to minimize a function of two variables: I figured out how to determine A, B and C coefficients in the y=ax^2+bx+c equation which approximates my data, so I think I already minimized the errors... but how do I get Cd and Crr out from these results?!?
Additionally, does it exist any tool allowing symbolic calculations, so I'm sure my steps in multiplying and adding polynomials are correct?
You are correct, I should have said "the function to find the best fit for" (which results in the function to minimize from #2). The function I wrote about in #10 is formulated in the terms of http://digilander.libero.it/foxes/optimiz/Optimiz1.htm, example 2, so that you could adapt that example to your needs.
Since you have found an implementation of the Levenberg-Marquardt algorithm, you do not need to know all its details. You do need to understand what it expects from you.
You cannot. As explained in #2, the real curve is not quadratic. It is given by $$ v = \frac 1 \alpha \tan (a \alpha t + \arctan \alpha v_i) $$ which looks like this: http://www.wolframalpha.com/input/?i=plot:+y+=+tan(2+-+x)+,+.45+<+x+<+2 The best you could do is fit the tangent-function curve to your quadratic curve, but that means you lose accuracy two times.
The site I just linked does. There is also commercial software doing that. Probably some freeware, too, but I cannot advise on that.
The simplest way to get your coefficients would be via two measurements of equal duration but different initial speeds. Then we have ##T_1 = T_2## and so ##\arctan \alpha v_{1f} - \arctan \alpha v_{1i} = \arctan \alpha v_{2f} - \arctan \alpha v_{2i} ##. Using Newton's method, $$ \alpha_{k + 1} = \alpha_{k} + {\arctan \alpha v_{2f} - \arctan \alpha v_{2i} - \arctan \alpha v_{1f} + \arctan \alpha v_{1i} \over {v_{1f} \over 1 + \alpha_k^2 v_{1f}^2} - {v_{1i} \over 1 + \alpha_k^2 v_{1i}^2} - {v_{2f} \over 1 + \alpha_k^2 v_{2f}^2} + {v_{2i} \over 1 + \alpha_k^2 v_{2i}^2}}$$ where ##\alpha_k## are successive approximations to ##\alpha##. Start with ##\alpha_0 = 0.001## and go till approximations become very close to one another.
The difficulty with this method is that the durations must be very accurately equal, which is probably going to be very hard to achieve in a mobile application. But this is something you could try. Repeated measurements and recalculations should show how successful your attempts are. If you see significant variation, then you will have to adopt the more complex method we discussed earlier.
Before I switch to better-fit equation you provided, which will require a lot more additional study by me :-( and also additional data recording, could you please give some hints about the quadratic approximation ax^2+bx+c ? I plotted the function obtained from least squares calculation, and it fits quite good to the experimental data:
Samples:
19,44
16,76
14,31
12,08
10,35
8,92
7,55
6,18Approximation:
19,45
16,72
14,30
12,17
10,34
8,82
7,60
6,68
Considering I already manually performed all algebric and matrix calculations which lead to A, B and C coefficients starting from experimental data, do I already have needed data/equations needed to determine Cd and Crr? Or do I need something else?
Alternatively, how could I use the formula you provided in #12 using current data, which all start from 70 kph?
As I said, the quadratic approximation does not help you at all.
You have samples of velocity at various times. Which you can interpret as a number of pairs ##(v_i, v_f)##.
I meant #14: you talk about 2 different start speeds so I thought you meant two series of samples starting at different speeds, but actually I now think you meant two different samples of same series.
Can you please check spelling of your formulas? I think there are some typos here and there (for example in #13; and in #10 i don't see any Y to replace)
Finally I don't understand how a and alfa relates to "my" K and H or to Cd and Crr .
Thanks for your precious help.
If you have four different samples in a series taken at times ##t_1 < t_2 < t_3 < t_4## such that ##t_2 - t_1 = t_4 - t_3##, then this is all you need. Or, if ##t_3 - t_2 = t_2 - t_1##, then you need just these three samples, and the speed measured at ##t_2## serves both as ##v_{1f}## and ##v_{2i}## (and you can simplify the formula a bit in this case).
I cannot see any problem in #13. In #10, there are typos. I can no longer edit that message, so I rewrite here correctly (I hope): $$ f(x_1, x_2, c_1, c_2) = \frac 1 {c_1 c_2} \left[ \arctan c_1 x_1 - \arctan c_1 x_2 \right] $$ where ##x_1 = v_f, x_2 = v_i, c_1 = \alpha, c_2 = a, y = T ##
There is no ##y## in the function, but for the purpose of the VBA algorithm it will be the time difference between the initial and final sample in a pair of samples.
From Newton's second law we have ## m \dot v = -R - D ## where ##m## is the mass, ##R## is the magnitude of the force of resistance to rolling, and ##D## is magnitude of the force of drag. We know further that ## D = d v^2 ##, so we have ## m \dot v = -R - dv^2 ## and so we have $$ \dot v = -{R \over m} - {d \over m}v^2 $$ So let $$ a = - \frac R m $$ and $$ \alpha = \sqrt {\frac d R } $$ then $$ \dot v = a(1 + \alpha^2 v^2) $$ ##d## and ##R## are constructed from ##c_d## and ##c_{rr}## and other constants similarly to your K and H, but mind the signs.
you'll drive me crazy with these typos... ;-)
Did you mean $$ \alpha = \sqrt {\frac d m } $$ ?
Wait, no there's no typo.
But you write
V'= d/m v^2 -R/m
I write:
v1-v0= K v0^2+H
How do they relate?
I don't think it's just
d/m = K
-R/m = H
even if I have constant time intervals. Or is that so?
I wrote $$ \dot v = - \frac d m v^2 - \frac R m $$ Note two minus signs. You have basically $$\Delta v = K v^2 + H $$ That means that $$ K = -\frac d m \Delta t $$ and $$ H = - \frac R m \Delta t $$
But I have a feeling that you are just getting yourself confused where it isn't needed. Just work out ##a## and ##\alpha## in the original constants, and be done with that.
Cutting, copying, pasting, adding, fixing, summarizing, shaking, adding a small icecube, and here it is what I get:
where
##m## is the mass,
##R## is the magnitude of the force of resistance to rolling ##( = mgC_r )##
##D## is magnitude of the force of drag ## ( = \frac 1 2 \rho A C_d v^2 ) ##
We set ##d = \frac 1 2 \rho A C_d## so we have:
## D = d v^2 ##
so we have
and so we have
So let
$$ a = - \frac R m = - \frac {mgC_r}{m} = -gC_r $$
and
$$ \alpha = \sqrt {\frac d R } = \sqrt {\frac {d}{mgC_r}} = \sqrt {\frac { \frac 1 2 \rho A C_d }{mgC_r}} = \sqrt {\frac { \rho A C_d }{2mgC_r}} = \sqrt {\frac { \rho A }{2mg}} \sqrt {\frac { C_d }{C_r}}$$
then
Reverse check:
$$ \dot v = -gC_r (1 + \frac { \rho A }{2mg} \frac { C_d }{C_r} v^2) = -gC_r - \frac { \rho A }{2m} C_d v^2 $$
$$m \dot v = -mgC_r (1 + \frac { \rho A }{2mg} \frac { C_d }{C_r} v^2) = -mgC_r - \frac { \rho A }{2} C_d v^2 = -mgC_r - \frac 1 2 \rho A C_d v^2 $$
$$ \frac {dv} {dt} = a(1 + \alpha^2 v^2) $$
$$ \frac {dv} {1 + \alpha^2 v^2} = a * dt$$
Integrating:
\int\limits_{v_i}^{v_f} {dv \over 1 + \alpha^2 v^2} = a \int\limits_{v_i}^{v_f} {dt} $$
where the i and f subscripts mean "initial" and "final", respectively.
$$\int\limits_{v_i}^{v_f} {dv \over 1 + \alpha^2 v^2} = a * (t_f-t_i) $$
$$ u = \alpha v \to v = \frac u \alpha \to dv = \frac {du} \alpha$$
$$ v = v_i .. v_f \to u = \alpha v_i .. \alpha v_f $$
$$ \int\limits_{v_i}^{v_f} {dv \over 1 + \alpha^2 v^2} = \int\limits_{\alpha v_i}^{\alpha v_f} { \frac {du} \alpha \over 1 + u^2} = \frac 1 \alpha \int\limits_{\alpha v_i}^{\alpha v_f} { du \over 1 + u^2} = \frac 1 \alpha (\arctan \alpha v_f - \arctan \alpha v_i)
Hence:
$$ \frac 1 \alpha (\arctan \alpha v_f - \arctan \alpha v_i) = a * (t_f-t_i) $$
$$ \frac 1 \alpha (\arctan \alpha v_f - \arctan \alpha v_i) = a * T $$
$$ \arctan \alpha v_f - \arctan \alpha v_i = a \alpha T $$
To determine Cd and Crr, which are contained in ##a## and ##\alpha## , I have to find ##a## and ##\alpha## that minimise the sum:
$$ \sum\limits_{n = 1}^N \left[ a \alpha T_n - \arctan \alpha v_{nf} + \arctan \alpha v_{ni}\right]^2 $$
because this is the sum of squared errors (squared error= (experimental - model)^2 ), and I want to minimize discrepancy (=errors) between experimental data and model.
The function to minimise, in terms of example 2 in this page, which says:
Example 2. Bi-dimensional gaussian regression
f(x1, x2, c1, c2, c2, c3, c4) = c4*exp(-(c1*x12 +c2*x22 +c3*x1*x2))
is
(1) ##f(x_1, x_2, c_1, c_2) = \frac 1 {c_1 c_2} \left[ \arctan c_1 x_1 - \arctan c_1 x_2 \right] ## (##c_1 x_1## and ##c_1 x_2## or ##c_1 x_1## and ##c_2 x_2## ? What about c3 and c4?)
where
##x_1 = v_f ##
##x_2 = v_i##
(2) ##c_1 = \alpha = \sqrt {\frac { \rho A }{2mg}} \sqrt {\frac { C_d }{C_r}}##
(3) ##c_2 = a = -gC_r ##
##y = T ##
In red my last doubts, to which I add:
is VBA source for "Example 2. Bi-dimensional gaussian regression" suitable in this case?
why do I have to minimise ## \sum\limits_{n = 1}^N \left[ a \alpha T_n - \arctan \alpha v_{nf} + \arctan \alpha v_{ni}\right]^2 ## ?
As far as I can see, ##a \alpha T_n - \arctan \alpha v_{nf} + \arctan \alpha v_{ni} ## is not the difference between measurement and model, it IS the model! Or not?
There are just two parameters in this model. I chose the second example so that you could see how to deal with two variables (x) and multiple parameters (c).
In an exact solution of the equation of motion, this should be zero (go back and compare this with the equation). So whatever non-zero value we have here is an error we want minimized.
What about the indexes? Are they correct in your formulas?
I have looked at every equation #22 and everything looks good there.
It looks like equation for just two samples shouldn't be that complex...
##=-2arctan(0,249361986 * sqr(A/m) * sqrt(Cd/Crr) * V1)*arctan(0,249361986 * sqr(A/m) *##
## sqrt(Cd/Crr) * V2) + arctan(0,249361986 * sqr(A/m) * sqrt(Cd/Crr) * V1)^2 + ##
## +arctan(0,249361986 * sqr(A/m) * sqrt(Cd/Crr) * V2)^2 + 2(-2,446241083 * t * sqr(A/m) *##
## *sqrt(Cd * Crr))*arctan(0,249361986 * sqr(A/m) * sqrt(Cd/Crr) * V1) + -2(-2,446241083 * t ##
##* sqr(A/m) * sqrt(Cd * Crr))*arctan(0,249361986 * sqr(A/m) * sqrt(Cd/Crr) * V2) + ##
## + 5,984095434 * t^2 * (A/m) * Cd * Crr##
all on one line.
Gosh.
I think I will adopt visual trimming of Cd and Crr until approximation better fits to samples...
I used the ##a, \alpha## notation for a reason :)
But if I put ##\frac 1 {c_1 c_2} \left[ \arctan c_1 x_1 - \arctan c_1 x_2 \right] ## on this site, shouldn't I see a function with a minimum value? I see a line.
I am not familiar with that site, and before I go exploring, I would like to remark that it would be pointless to find minima of that function. It is meaningless for the problem at hand, and there is no minimum to be begin with.
Is this equation, provided in previous page, correct?
With:
$$ a = -gC_r $$
$$ \alpha = \sqrt {\frac { \rho A }{2mg}} \sqrt {\frac { C_d }{C_r}}$$
it would become:
$$ v = \frac {1}{ \sqrt {\frac { \rho A }{2mg}} \sqrt {\frac { C_d }{C_r}}} \tan (-gC_r ( \sqrt {\frac { \rho A }{2mg}} \sqrt {\frac { C_d }{C_r}}) t + \arctan ( \sqrt {\frac { \rho A }{2mg}} \sqrt {\frac { C_d }{C_r}}) v_i) $$
