Calculating dimensions of power
  • Thread starter Thread starter fran1942
    Dimensions Power
2 replies · 5K views
fran1942
Calculate basic dimensions of power using MLT notation.
2. Given information:
E= P*t
E= .5*mass*velocity^2
Rearranging E=Pt to P=E/t
a) P = (.5 mass * velocity^2) / seconds * seconds^2
b) P = (.5 kg * metres^2) / seconds^3
c) moving to one line: .5 kg * metres^2 * seconds ^-3
However I know I have the .5 component wrong. It should not be there. Can someone please point out where I have gone wrong ?
Thanks for any help.
E= P*t
Energy is the capacity to do work, where work = force * the distance through which the force is applied. The work-energy theorem says that work done to a body equals its change in energy. When the change is energy is manifested as a change in speed, we say the kinetic energy has changed, and the formula of kinetic energy is 0.5mv2.
The easy answer is that you are looking for units, which means you don't need to pay attention to the 0.5. The units of energy are kg*m2/s2. But that's not very satisfying.
When the work is done against an attractive or repulsive force, we say he potential energy changes. PE = mgh.
You could avoid introducing the 0.5 by starting with the formula for work or for potential energy.
Simple, quick answer: when you're just figuring out units, ignore the numbers in the formula.
Simple example:
diameter = 2 x radius​
Both diameter and radius are measured in meters. We do not say that if the radius is measured in m, then the diameter must be measured in units of 2 m.
