Calculating displacement current and magnetic field.
9 replies · 3K views · last reply
weezy
1. The problem statement,
A capacitor is there in free space consisting of 2 circular plates of radius ##r## separated by a distance ##z## which is a function of time. ##z(t) = z_0 + z_1 cos (\omega t)##; ##z_0(<<r)## and ##z_1(<z_0)## are constants. The separation ##z(t)## is varied in such a way that the potential difference ##V_0## between the plates remains constant.
  • Calculate the displacement current density & displacement current between the plates through a concentric of radius ##\frac{r}{2}##
  • Calculate ##\vec H## between the plates at a distance of ##\frac{r}{2}## from the axis of the capacitor.
Now, ##\oint_{\frac{r}{2}} \vec H \cdot d\vec l = \int_S \vec J \cdot d\vec a + \int_S \vec J_d \cdot d\vec a## where ##J_d## is displacement current density. I hope to use this equation and equate ##J=0## and find out ##J_d## in the region between the plates. What I don't understand is how to use the condition ##V_0 = constant## to solve this problem. I calculated the capacitance ##C(t) = \frac{A\epsilon}{z_0+z_1 cos(\omega t)}## and that's it. I'm stuck.
EDIT 1: I think the way to go is to use ##\vec E(t) = -\nabla V(t)## where ##V(t) = \frac{Q}{C(t)}## but I'm not sure if ##Q## is also a function of time. Is it?
How do you propose to find the displacement current?
I updated the question. See Edit 1. I think I have to find ##\partial_t \vec E## first but I'm not sure if ##Q=Q(t)##.
The V(t) in ##\vec{E} = -\nabla V(t)## and ##V(t) = \frac{Q}{C(t)}## aren't the same quantity. The V in the first expression is also a function of the spatial coordinates, otherwise you'll get 0 when you take the gradient. The V(t) in the second expression is the potential difference across the capacitor; you were told it's equal to a constant ##V_0##. (That should answer your question about whether Q is a constant or not.)
You're on the right track though. You want to relate the electric field inside the capacitor to the potential difference across the plates.
vela said:
The V(t) in ##\vec{E} = -\nabla V(t)## and ##V(t) = \frac{Q}{C(t)}## aren't the same quantity. The V in the first expression is also a function of the spatial coordinates, otherwise you'll get 0 when you take the gradient. The V(t) in the second expression is the potential difference across the capacitor; you were told it's equal to a constant $V_0$.
But the question seems contradictory to me. if ##V_0## is constant then how can a displacement current exist? Does the constant V_0 imply a fixed charge on the capacitor?
The charge on the capacitor is equal to Q = C(t)V0. Do you still think the charge is fixed?
Obviously no. That was my first thought! But I don't see another way to explain ##V_0## = constant. Moreover I don't even see why that is a necessary condition in this question.
SO I did this :
## - \int _{0}^{z_0+z_1cos(\omega t)} \vec E \cdot d\vec l = V_0 \implies E= -\frac{V_0}{z_0+z_1cos(\omega t)} ## or ##\partial_t E = \frac{V_0z_1sin(\omega t)}{z_0+z_1cos(\omega t)}##. Is this the right way?
Yes, but the denominator should be squared in your final result.
Oops. Sorry for that!
