Calculating elastic modulus in a certain shape
To calculate the elastic modulus (E) in the context of a square cross-section that deforms by 0.8 mm, it is essential to recognize that E is a material property independent of shape. The discussion raises the need to clarify whether the column is tapered and the type of material involved, such as wood or steel. Understanding the specific loading conditions and geometry is crucial for accurate calculations. The deformation indicates that axial load is likely applied, which affects the stress and strain relationship. Proper identification of these factors will lead to a more accurate determination of the elastic modulus.
veeelsooon
http://imgur.com/oLMkHBX
How exactly would you calculate E in this? The cross section is a square and it deforms .8 mm. I'm not quite sure what to do since obviously the size of the cross section changes.
The elastic modulus is a property of the material and not the shape. Is this a square cross sectioned tapered column subject to axial load? Wood, steel, other?
Is this a homework problem?
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
28K
  • · Replies 53 ·
10K
