Calculating Electric Force in a Dipole at Long Distances
The discussion revolves around calculating the electric force on a proton placed at a long distance from an electric dipole, which consists of two equal and opposite charges separated by a distance of 2a. The original poster seeks to demonstrate a specific relationship for the electric force in this context.
  • Participants discuss the orientation of the dipole and its impact on the force calculations. There are attempts to apply the Pythagorean theorem to relate distances and forces, as well as considerations of vector components in the force exerted on the proton.
Some participants have provided guidance on how to approach the problem, particularly regarding the cancellation of y-components of the forces and the implications of the dipole's orientation. Multiple interpretations of the setup are being explored, but there is no explicit consensus on the final approach or solution.
Participants are working under the constraints of a homework assignment, which may limit the information they can share or the methods they can use. There is an emphasis on demonstrating the relationship rather than simply applying formulas.
cathb
Hi,
I had this question in my homework:
An electric dipole consists of two equal loads and signs opposite separated by one distance which equals 2a. Show how the module of the electric force resulting on a proton (load +e) placed directly on the Y=axis at a very long distance from the dipole (y>>a) is given by Fe = 2aekq/y^3
The usual equation for the electric force is: Fe= keq/r^2
I tried to replace the distance r^2 with Pythagore: a^2 + y^2 = r^2, but i didnt find the y^3
Could anybody help me?
Is the dipole oriented along the x-axis or the y-axis?
Assuming the dipole is oriented along the x-axis, place charge q at x=a/2 and charge ‒q at x = ‒a/2. Find the vector sum of the force each charge in the dipole exerts on the proton. (The y-components of the two forces should cancel, leaving only the x-components.)
Hi,
Thanks for your reply. I actually have the same homework and I'm having trouble with the same question.
Here is the image of the dipole in question. My issue is how do we actually demonstrate that the module of the electric force resulting on a proton (load +e) placed directly on the Y=axis at a very long distance from the dipole (y>>a) is given by Fe = 2aekq/y^3 (i think I'm just not getting it at all... sorry :S)
I didn't read closely enough.
Place charge ‒q at x=a and charge +q at x = ‒a, as in the figure.
The force, F, on the proton, due to charge ‒q is: F= ____ ? (It's a vector.)
The force, F+, on the proton, due to charge +q is: F+= ____ ? (It's also a vector.)
Thank you for your help,
in brief, i only found the vector on the x-axis (cuz as you said the y-component should be canceled) and replaced the sin by tan (because of the very long distance of the y-component of the proton, which was nearly equal to the distance between the proton and one of the chage q). So the tan would be replaced by a/y.
in brief, i only found the vector on the x-axis (cuz as you said the y-component should be canceled) and replaced the sin by tan (because of the very long distance of the y-component of the proton, which was nearly equal to the distance between the proton and one of the charge q). So the tan would be replaced by a/y.
If r2 = a2 + y2, then for y » a, r2 ≈ y2.
That should get you your desired result.
Thanks a lot
You're very welcome.
