Calculating Electron Energy with Uncertainty Principle: Homework Example
5 replies · 3K views
v_pino
Using the uncertainty principle, estimate the minimum energy in electron volts of an electron confined to a spherical region of radius 0.1nm.
delta-x * delta-p = h-bar / lamda
delta-y * delta-p = h-bar / lamda
delta-z * delta-p = h-bar / lamda
Energy = 0.5* p^2 / m
p = momentum
m = mass of electron
By letting the uncertainty in position (delta-x, delta-y, delta-z) equal to r, I got 2.86eV :
Total energy = 3/8 * (h-bar^2 / r^2 * m)
But the answer should be ~ 10ev.
[STRIKE]If the electron is confined in a spherical region, the uncertainty in X is given by [tex]\Delta X = X_{2} - X_{1}[/tex]
So taking the centre of the sphere as 0, you will have 0.1nm and -0.1nm as X[tex]_{2}[/tex] and X[tex]_{1}[/tex] respectively, [tex]\Delta[/tex]X will then be 0.2nm
Hope this helps ;)[/STRIKE]
Mulling it over a coffee. Brb.
This will make matters worse by a factor of 4. Also on the right hand side of the uncertainty inequality there should be a 1/2, which would give an additional factor of 4 in the wrong direction. Are you sure the given answer is correct.
Sure, no. I'll consider over a coffee.
One can derive the general uncertainity principle by using the standard deviation method of statistics.
Here delta(x) and delta(p) are standard deviations.
(delta(x))^(2)=|<x^(2)>-<x>^(2)|
(delta(p))^(2)=|<p^(2)>-<p>^(2)|
So how does this help solving the problem at hand?
