Calculating Electron Velocity in a Magnetic Field
  • Thread starter Thread starter ekinnike
In a Year 12 physics homework question, a magnetic field of 1.00 x 10^-2 T allows electrons to pass through electric deflection plates spaced 10 mm apart with a potential difference of 300 V. The strength of the electric field between the plates is calculated to be 3 x 10^4 V/m. To find the speed of the electrons as they enter the plates, the relevant formulas include F = qvB and E = V/d. The magnetic force acting on the electrons can be determined once the velocity is known. Additional resources, including a diagram of Thomson's electromagnetic experiment, were suggested to aid in solving the problem.
ekinnike
This question is in my yr 12 homework textbook.
q21.keyword e=exponential in case if i confused u .
In a tube similar to that used in the Thomson's electromagnetic experiment, a magnetic of 1.00 x 10e-2 T is sufficient to allow the electrons to pass through the electric delfection plates. The plates are 10 mm apart and have a potential difference of 300 V across them.
(a) what is the strength of the electric field between the plates? 3x10e4 vm(i did and checked with the book)no problem with this question...
(b)What was the speed of the lectrons as they entered the region between the plates? working on...
(c) what was the strength of the magnetic force acting on the electrons.
havent try
i only have some formulas to work with it
F = qvBsinO v=velocity
E = V/d V=voltage
v= B/E <--- not quite sure about this .i tried to apply for (b) but didnt quite get the answer. I have answer at the back of book but i can't work it out...
thanks in advanced
I'm not familiar with Thomson's electromagnetic experiment. Could you provide a link to a diagram? You are correct that you need the velocity v from answer (b) in order to calculate the magnetic force F=qvXB.
http://library.thinkquest.org/13394/angielsk/athompd.html <-- i just googled it. not sure if it useful
Well, it certainly looks like there is enough info in that link to help you solve your homework problem. Especially the explanation and equations about 3/4 of the way down. Don't they help you with question (b) about the required velocity...?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
