Calculating Energy of Electrons Propogating in Cu Using Bragg's Law
  • Context: Graduate
  • Thread starter Thread starter heardie
    Electrons Law
The discussion revolves around calculating the energy of electrons propagating in copper (Cu) using Bragg's Law, specifically focusing on the [100] and [110] directions. Participants explore the implications of lattice parameters and electron interactions within the context of solid-state physics.
  • One participant proposes using Bragg's Law, $2d_{hkl} \sin \theta = n\lambda$, and expresses uncertainty about the angle theta, suggesting it might be 90 degrees based on previous experiences with electron-lattice interactions.
  • Another participant mentions that the use of Bragg's Law is typically associated with determining unit cell structures and questions how it applies to electronic transport.
  • A different participant emphasizes the condition that $\sin(\theta) \leq 1$, leading to the conclusion that $\lambda \leq d_{hkl}$.
  • Concerns are raised about the implications of electrons reflecting at 90 degrees when propagating in the [100] direction and how this might affect other planes.
  • One participant calculates energies of 11.5 eV and 23 eV for the [100] and [110] directions, respectively, and argues that these energies being greater than the Fermi energy of Cu (7 eV) supports the assumption of free electron behavior.
  • Another participant presents 'official' answers of 2.89 eV and 1.45 eV, noting that the energy gap due to lattice interactions is significantly below the Fermi energy, reinforcing Cu's metallic nature.
  • One participant corrects a previous misunderstanding regarding the factor of 2 in Bragg's Law and suggests that as long as the energy is not near the Fermi energy, the free electron model remains valid.
  • A later reply introduces an alternative form of Bragg's Law using the reciprocal lattice vector and derives energies for both directions, concluding that the Fermi energy being below the Bragg plane energy indicates that the free electron model is applicable.
Participants express differing views on the application of Bragg's Law to electronic transport and the appropriate assumptions regarding theta. While some calculations yield energies that suggest free electron behavior, there is no consensus on the correct approach or the implications of the results.
Participants note limitations in their assumptions, particularly regarding the angle theta and the conditions under which Bragg's Law is applied. The discussion reflects a range of interpretations and calculations that depend on specific definitions and assumptions about electron behavior in a lattice.
heardie
Hi - come across a problem I am unsure if I am doing the right way.
At what energy is Bragg's Law satisfied to first order in Cu given that the lattice parameter is a=0.361nm
i) Electrons propagate in the [100] direction
ii) [110] direction
My basic step was
$2d_{hkl} \sin \theta = n\lambda $<br />
$d_{hkl} = \frac{a}{{\sqrt {h^2 + k^2 + l^2 } }}$<br />
I was unsure what to do with theta, however I seem to recall coming across a similar problem, where we assumed electon-lattic interctions caused a reflection, so theta=90. However this seems a little hazy to me.
So upon finding the wavelength I then used
$E = \frac{{\hbar ^2 }}{{2m}}\left| k \right|^2 {\rm{, where }}k = \frac{{2\pi }}{\lambda }$<br />
I think I got about 2 ev. Is this the right approach?
And finally...comparing this to the Fermi energy of Cu (7ev), "comment on the significant of this comparision with respect to the assumption of free electrons in Cu". Since E < E[f], do I conclude this is a good assumption??
Thanks in advance
This is a little different from the way I'm familiar with using Bragg's Law. If you are doing X-ray or electron diffraction off a crystalline solid, the ratios of the sines of the peak angles tell you what the unit cell structure is (bcc, fcc, etc.), and the values of the angles tell you the plane spacing (or lattice parameter).
Have not thought about how to use Bragg's Law to deal with electronic transport within the lattice. Clearly, as you've indicated, "what is theta ?" is a good question that need resolving. Hmmm...will think about this.
I think you want to say that sin(\theta) &lt;= 1, so<br /> \lambda &lt;= d
This cannot be wrong...but may not be sufficient.
If electrons are propagating in the [100] direction they are traveling perpendicular to a plane though the x-axis. Thus when they interact with that plane, they are reflected at 90 deg. What about all other planes? this is bothering me!
Using a=0.361nm and theta=90 (i.e. normal incidence and 180 change in direction or back scattering) gives Lamda=a, and Bragg's law is satisfied for Ea=11.5eV (23eV) for i (ii). Try your numbers again, and see if you agree.
So this is the opposite. Ea>Ef=7eV, which makes Cu free electron like, and is thus a good assumption. If Ea=Ef, then one has the extreme case of an insulator, ie NOT a free electron. Internal electrons keep getting backscattered because of the lattice periodicity, and therefore do not move, hence an insulator.
Well I have the 'official' answersr now: 2.89eV and 1.45 eV
In both cases the opening of the enegry gap due to the lattic interaction or Bragg reflection, is well away from the Cu Fermi energy of 7eV. The condunction band of Cu is always partially filled, and Cu maintains its metallica nature.
Right, the Bragg law is
2*d_hkl*sin(theta) = n*Lamda
I was using the what you wrote without the factor 2. Still, as long as the energy isn't in the vicinty of Ef, free electron model is fine I think.
Use a different form of Bragg's law
Hopefully, I won't mess up the Latex typsetting too much, I'll try to come back and fix it later.
a = .361 nm
Braggs law using the Reciprocal lattice vector G is
k = (1/2)G
Then the energy is
E = {hbar^2}{k^2}/(2m)
Ignore the first "/" in this equation. I can't edit it out!
{k^2}= (1/4){G^2}
which is needed in the equation for the energy that was given in a post above.
G = h b _1 + kb_2 + l b_3
where h,k,l are the miller indices and the b's are the primitive lattice vectors for the fcc recpirical lattice.
So for the first part in the [100] direction,
{G^2} = b^2_1
The result for the energy is
E = 3 {hbar^2}{pi^2}/({a^2}{2m})
= 3 * 2.89 eV = 8.6 eV
For the [110] direction,
G = b_1 + b_2
{G^2} = b^2_2 + 2b_1 b_2 + b^2_1
and the energy is
E = 4 {hbar^2}{pi^2}/{a^2}2m
= 4 * 2.89 eV
= 11.5 eV
The fermi energy for Copper is 7 eV. The fermi energy is the energy of the uppermost electrons. Since this energy is below the top of the bands (which are at the Bragg planes) the band is only partially filled and Copper is a metal. In previous posts, the assumption was made that theta = 90, this assumption cannot be made.
According to the nearly free electron model, the major effect of the lattice is at the Bagg planes. Since Copper's fermi energy is well below the Bragg plane energy, the free electron model works.
  • · Replies 20 ·
11K
