Calculating Energy Required for Phase Change in an Ice Cube
5 replies · 7K views
free-node-5
How much energy is required to change a 46.0 g ice cube from ice at -10.0°C to steam at 116°C?
specific heat
c = Q/(m(Tf-Ti))
Q = cm(Tf-Ti)
latent heat
Q = mL
2.05*10*46+4.1813*100*46+2.080*16*46 + 2260*.046+334*.046
= 21827.184J
(please only speak in metrics or you'll lose me)
can anyone help me figure this out?
It's very crucial that I understand this process.
thanks
Looks like the right technique, you should put some units into make sure that you didn't lose anything.
It's also normal to work in base units eg kg,
heat ice 10deg = 2.05 J/gk *10k *46g = 943 J
melt ice = 333.5 J/g * 46g = 15340J
heat water 100deg = 4.1813 j/gK * 100k*46g = 19300J
boil water = 2260 kJ/kg * 46g = 2260 J/g * 46g =104000J
heat steam 16deg = 2.080 J/gk *16k*46g = 1530J
Total 140K Joules
apparently the table on wikipedia was using kJ/kg which threw me off
2.05 J/(gK) *10 K*46g+4.1813 J/(gK) *100K*46g+2.080 J/(gK) *16K*46g + 2260J/g*46g+334J/g*46g
= 141031.86
I still don't know if this is right though
I also need to know if I was supposed to be adding for the ice to melt of subtracting the latent heat energy (it may be releasing energy when it melts as opposed to absorbing it)
That's why I suggested writing it out as above.
Then it's more obvious if a number is wildly wrong
eg,
warming ice 10 deg small amount of energy
melting ice = a lot of energy (it takes along time for freezer to defrost)
heating water 100deg = a lot of energy (think how long it takes to make a coffee)
boiling water = a lot of energy, that's why steam is so powerful
heating the steam = small energy
The energy flow is all in the same direction (same sign) at each step you are putting energy in
nothing you're saying is incredibly unreasonable... but I never tried to convert kj to j
(I did however have numbers from wiki. that said x kJ/kg
which is inherently equal to J/g)
