Calculating the energy required to spool a turbocharger
Calculating the energy required to spool a turbocharger involves understanding the relationship between the turbo's inertia and engine output. The formula for energy is E = 1/2 Iω², but the time to reach full speed does not affect the energy needed to achieve a specific RPM. The engine's output is primarily influenced by the turbocharger's mass flow rate, which varies with RPM, rather than the energy required to spin the turbo. Therefore, knowing the energy to spin up the turbo does not directly correlate with engine performance metrics. The discussion emphasizes the complexity of these relationships in turbocharger dynamics.
devon1996
I am interested in figuring out a general formula for how much energy it takes to spin up a turbocharger if we know the diameter of the wheel,mass, target rpm, and time to go from stationary to full speed. The goal is to get a general idea of what engine speed is required to get a turbo to spool on any engine configuration. Once I have the formula I want to compare known dyno graphs to see how the energy to overcome inertia compares to engine output when the turbo spools
This is so wrong on so many levels.
Simple, ##E = \frac{1}{2}I\omega^2## (source)
It has no influence on the amount of energy needed to reach a certain rpm.
Knowing how much energy it takes to spin up a turbocharger won't help you for that.
You will not find out any relationship between the two.
The engine output will depend mostly on the turbocharger mass flow rate, which in turn will depend on the turbocharger rpm. So it doesn't mean that if the energy doesn't go to the engine output, that it goes to spin the turbocharger. It is just that there is not the same amount of air that goes into the engine at different turbine rpm.
This was my line of thought. On a gasoline engine every horsepower you make you put one horsepower worth of heat into the exhaust and one into the cooling system. So if it took say 50 hp to bring the turbine up to speed plus 10 hp to compress the air at that speed you'd need say 60 hp worth of exhaust flow to make whatever boost. And so then you could go to a dyno graph and see if it spooled at say 80 hp or whatever.
  • · Replies 60 ·
