Calculating field strength mV/m at distance d - check me
The discussion centers on calculating electric field strength in mV/m at varying distances from an omni-directional antenna. The participants confirm that electric field strength is inversely proportional to the square of the distance for point charges, but clarify that for radio signals, the amplitude varies as 1/r in the far field. A formula for calculating electric field strength from a grounded monopole antenna is provided: (300 sqrt P) / D, where P is power in kW and D is distance in km. The calculations presented are validated, with specific examples showing electric field strength at different distances.
  • Understanding of electric field strength and its relationship to distance
  • Knowledge of radio signal propagation principles
  • Familiarity with the formula for electric field strength from antennas
  • Basic arithmetic skills for calculations
  • Research the differences between near-field and far-field propagation of radio waves
  • Learn about the impact of ground losses on antenna performance
  • Explore the use of field strength calculators for practical applications
  • Study the effects of frequency on electric field strength measurements
Electrical engineers, radio frequency (RF) engineers, and anyone involved in antenna design and radio signal analysis will benefit from this discussion.
Fran3
it's been awhile for me so check if I'm remembering this right... Thanks.
electric field strength is inversely proportional to distance squared... right?
So if the electric field strength is 1,000 mV/m at 1 meter then the following is true... right?
km______mV/m________ the math
1________1000 .00______=reference point
2_________250.00_______ =1000/(2^2)
3_________111.11________=1000/(3^2)
4__________62.50________=1000/(4^2)
5__________40.00________etc
thanks for any help.
...from a point charge. If the source of the field is a point charge, or at least small enough compared to the distances involved, that a point is a good approximation, then your calculations are correct.
This depends on your setup. It is true for a point charge or a spherically symmetric charge distribution.
In this case we are talking about field strength of a radio signal being radiated from an omni-directional antenna.
In the example the radio signal measures 1,000 mV/m at a distance of 1km and we want to calculate the field strength at different distances.
Ignoring any mitigating factors such as attenuation through structures or whatever... are our calculations correct for what we could consider near-field distances and also characterize as "ground wave" distinguishing from "sky wave" or "skip".
thanks for the help.
This is different from the electrostatic field of a point charge. In this case, in the far field the amplitude of the electromagnetic wave varies as 1/r, not 1/r2. It's the radiated power density (W/m2) that varies as 1/r2.
A convenient formula for the electric field strength from a grounded monopole antenna in mV/m is (300 sqrt P) / D, where D is distance in km and P is power in kW. It is necessary to be very careful about ground losses, especially where the frequency exceeds about 1 MHz.
So if
P=4kW
D=2km
electric field strength = ([300*sqrt(4)]/2) = 600/2 = 300 mV/m
and for D=4km
electric field strength = ([300*sqrt(4)]/4) = 600/4 = 300 mV/m
correct?
and thanks !
Fran3 said:
600/4 = 300 mV/m
Check your arithmetic. :oldwink:
Woops! When you cut and paste you should complete all the edits in the pasted text. Yep, should have read...
So if
P=4kW
D=2km
and for D=4km
electric field strength = ([300*sqrt(4)]/4) = 600/4 = 150 mV/m
And Dave, thanks for the link. Very handy.
  • · Replies 16 ·
  • · Replies 32 ·
