Calculating Flow from Tank to Vessel w/ Power
19 replies · 3K views
GSXR-750
I am trying to calculate the flow in a system from an underground tank up through a pump into a vessel.
But cannot find or derive a formula that yields a good result, I don't think I can use the same head calculations as Velocity will have changed.
1. Homework Statement
ρ = 1000 kg m–3
μ = 0.001 Pa s
P1 = 1bar
P2 = 2bar
Area/Diameter of pipe mm = 0.00636/90
Power = 2749 Watts
Image 1
[/B]
I have attempted using ##Re= \frac {UcdP} {p},##
(assuming streamlined)##2000= \frac {Uc*0.09*1000} {0.001},##
## Uc= \frac {2000} {90000},##
##Uc = 0.02 ms^{-1}##
## Flow = Velocity * Area ##
= 0.02 * 0.00636
## = 0.00013m^3s^{-1}##However I haven't used power here so I cannot see it being the correct way to calculate the flow.
From my notes this equation looked to give a reasonable answer. It however finds the Critical Velocity, which I now see is the velocity in which the flow changes into turbulent flow.
I used 2000, as I know from a previous question using the exact same system but given a flow, different Viscosity and density, that the pipework is laminar.
Is there a way to transpose the old Viscosity and density with the new one to find flow or velocity?
I am told the solution may require an iterative solution.
Thanks
Suppose, instead of knowing the power supplied to the pump, you knew in advance the velocity of the flow in the pipe. Could you then solve for the power supplied to the pump?
The question states using the same pump as before. So I think I need to use the power previously stated and work backwards to velocity and hence flow.
That wasn't my question. I'm not asking about your specific problem. Read my question carefully. If I told you that the flow in the pipe is 3 m/s, would you be able to calculate the power required from the pump to achieve this flow? Yes or no.
Given Fluid information and heads calculated from Velocity. Using Darcy Formula
Good. Do it. Let's see what you get for the power.
So I calculated Flow to be ##0.0019m^3s##
Hm = 0.023m
Hf = 1.97m
Therefore using Darcys Equation is ended up with Hp to be 29.18 (very similar to my previous fluid)
Which gave me a Power of 858 kW.
From this I assume that Hp won't change much in this given system.
Hence from my first question. ##Q= \frac {2749} {1000*9.81*29.19} ##
Thanks
I apologise I inputted Velocity not flow. The answer should be 5441 Watts or 5.4 Kw.
Hm stands for the frictional losses caused by fittings. Though I'm now looking thinking my overall process for Hf is incorrect.
I now think it should be 5069 Watts
For a velocity of 3 m/s, I get a volumetric flow rate (assuming a diameter of 0.09 m) of 0.0191m^3/s. Is this what you got?
I get a mass flow rate of 19.1 kg/sec.
I get a Reynolds number of 270000. Is this what you get?
For a smooth pipe, I get a Darcy Weisbach friction factor of about 0.15. Is this what you got?
I get a velocity head of 0.459 m.
I get a frictional head of about 24.5 m. Is this what you get?
The pressure head and the gravitational head are both independent of flow rate.
Pressure head = 1 bar = 10 m
Gravitational head = 16 m
Is this your assessment?
Thanks for you patience with me
I got the Flow rate, mass flow rate, Reynolds and velocity head. I don't believe i have studied finding the Darcy Weisback friction factor.
I think my frictional head loss is 23.29 as I was going from the water surface not the whole leg i.e. 17m height.
Then you must be using Fanning. Darcy Weisback friction factor is 4 x Fanning, and, in the DW equation, you only use L/D, compared with than 4L/D with Fanning.
The frictional head should be based on the total length of pipe, 32 meters.
