Calculating Force Exerted by Laser Beam on a Mirror
In summary, when a laser beam with a power of 1W is reflected by a mirror perpendicular to the beam, the force with which light pushes the mirror can be found by using the equations for energy and momentum of photons. This results in a force of approximately 6.67 x 10^-9 N. The 2 in the formula for force comes from the fact that the change in momentum is twice the original momentum, which is due to the reflection of the light off the surface of the mirror. If the light was absorbed instead of reflected, the 2 would be a 1.
Matthaeus_
A laser beam ([tex]\mathrm{Power} = 1\ \mathrm{W})[/tex] is completely reflected by a mirror perpendicular to the beam. Light is made of photons, and each photon carries an energy [tex]E = h\nu[/tex] and a momentum [tex]P = h/\lambda[/tex], where [tex]\nu[/tex] is the frequency, [tex]\lambda[/tex] is the wavelength and [tex]h[/tex] is Planck's constant. Find the force with which light pushes the mirror.
Apart from those already present in the problem statement, I have:
[tex]\lambda \nu = c[/tex]
[tex]F = \frac{dp}{dt}[/tex]
Each second, the light source emits [tex]n[/tex] photons, each one carries an energy [tex]E = h\nu = hc/\lambda[/tex], for a total power of [tex]1\ \mathrm{W}[/tex]. This gives:
[tex]\displaystyle n = \frac P E = \frac{\lambda}{hc}[/tex]
In one second then, [tex]n[/tex] photons hit the mirror and bounce back, which gives:
[tex]\displaystyle F = \frac{dp}{dt} = n \cdot 2p = 2 \frac{\lambda}{hc}\cdot \frac{h}{\lambda} = \frac 2 c \approx 6.67\cdot 10^{-9}\ \mathrm{N}[/tex]
The result is somewhat intuitively pleasing, can you check it is correct, please?
Looks good to me.
Whew... Thank you Doc for checking :)
Sorry to dig up such an old question, but after looking at this question, I don't understand were the 2 comes from in the F=n2p. Could someone explain this to me?
Thanks
The momentum is twice the incoming photon's because it bounces back
Think of a ball, if you throw it to hit a wall and stop then you need twice as much force for it to hit the wall and come back at the same speed.
That is to say, if it was not a mirror, and the light did not reflect off the surface, the 2 would be a 1 instead?
It comes from the fact that the change in momentum is twice the original momentum.
Yes. If the light is absorbed then it's a 1. As Doc Al said, it's all about change in momentum.
Related to Calculating Force Exerted by Laser Beam on a Mirror
1. What is the force exerted by a laser beam?
The force exerted by a laser beam is the physical push or pull that the laser beam exerts on an object due to its transfer of energy. This force is typically measured in Newtons (N).
2. How is the force exerted by a laser beam calculated?
The force exerted by a laser beam can be calculated using the formula F = P/c, where F is the force in Newtons, P is the power of the laser beam in Watts, and c is the speed of light in meters per second.
3. What factors can affect the force exerted by a laser beam?
The force exerted by a laser beam can be affected by factors such as the power of the laser, the distance between the laser and the object, and the properties of the object (e.g. reflectivity, absorption, etc.). Additionally, the wavelength and color of the laser can also impact the force exerted.
4. Can the force exerted by a laser beam be harmful to living organisms?
Yes, the force exerted by a laser beam can be harmful to living organisms if the power and duration of exposure are high enough. This can result in burns, eye damage, or other injuries. It is important to follow safety precautions and guidelines when working with lasers to avoid potential harm.
5. How is the force exerted by a laser beam used in scientific research?
The force exerted by a laser beam is used in various scientific research applications, such as optical tweezers, laser microsurgery, and laser ablation. These techniques utilize the force of a laser beam to manipulate or interact with microscopic objects or biological samples, providing valuable insights and advancements in fields such as biology, medicine, and physics.
