Calculating Force Exerted on Football Tackler
  • Thread starter Thread starter mathcrzy
To calculate the average force exerted on a tackler stopping a 110 kg fullback running at 4.9 m/s, the impulse-momentum theorem is essential. The initial momentum of the fullback can be calculated using his mass and velocity, resulting in 539 N, but this value alone does not represent force. Instead, impulse, defined as the product of force and time, should be used, where impulse equals the change in momentum. The change in momentum can be determined by knowing the fullback's initial momentum and that he comes to a stop. Thus, the average force can be derived from the impulse equation, leading to a more accurate calculation of the force exerted during the tackle.
mathcrzy
A 110 kg fullback is running at 4.9 m/s to the east and is stopped in 0.75 s by a head-on tackle by a tackler running due west. Calculate the average force exerted on the tackler.
Magnitude
____N
F=ma
F=110*4.9=539N
4.9 m/s is velocity, not acceleration. So it doesn't work in that equation. Look up impulse.
Impulse=F*deltaT
=(110*4.9)*.75
=404.25
You are trying to find F though. You can find impulse by considering the change in momentum of the player. Once you have that, you can then find the average force.
would you use the equation (before the collision) M1*V2+M2*V2=M1*V2+M2*V2 (after the collision)
That's the right idea, you need to find the change in momentum of the fullback. You were given his initial velocity, so you know the initial momentum. You know he is brought to a stop, so you also know his final momentum.
