Calculating Force in a Falling Man: An 88kg Example
8 replies · 2K views
missashley
An 88 kg man drops from rest on a diving board 3.3m above the surface of the water and comes to rest 0.58 seconds after reaching the water.
Acceleration due to gravity is 9.81 m/s^s
What force does the water exert on the man? in N
F = ma
a = v/t
3.3/0.58 = 5.689655172 m/s = v
F = 88 * 5.689655172 = 500.6896552 N
F = 500.6896552 N
Did I do this right?
First you need the speed he hit the water - you got this wrong
v^2 = u^2 + 2 a h
V^2 = 2 * g * 3.3 , v = 8.05m/s
Then the accelaration (rate of slowing down) in the water
V = u + a t,
so 0 = 8.05 - a * 0.58
a = 13.8 m/s^2
Then F = ma
Don't we need to know the force the diving board exerts on the man, too? http://www.turboconnection.com/pics/smilies/hmm.gif
Never mind. He doesn't drop on to the diving board; he drops off the diving board and into the water.
Start with this equation to figure the speed he's at when he hits the water:
(1) [tex]a \Delta{x} = \frac{1}{2}(v^2-v_0^2)[/tex]
Then use this equation to find his acceleraction (deceleration) when he's in the water:
(2) [tex]x=x_0+v t+\frac{1}{2}a t^2[/tex]
Equation 2 can be simplified into terms of only velocity and acceleration by differentiating it with respect to time, as such:
(3) [tex]v=v_0+at[/tex]
Then apply the definition of force:
(4) [tex]F=ma[/tex]
That should do it.
v^2 = u^2 + 2 a h
V = u + a t,
a = 13.8 m/s^2
Then F = ma
Wouldn't a = 4.667 because 8.05 * 0.58 = a
never mind 8.05 / .58 = 13.873
(4) [tex]F=ma[/tex]
That should do it.
How do I find the velocity?
v^2 = u^2 + 2 a h
V = u + a t,
a = 13.8 m/s^2
Then F = ma
yay i got it right! thanks a lot!
Use the first equation. You know [tex]a[/tex]:
[tex]a=-g=-9.8\frac{m}{s^2}[/tex]
You know initial velocity:
[tex]v_0=0[/tex]
And you know the change in distance:
[tex]\Delta{x}=-3.3m[/tex]
Actually, it should be
[tex]\Delta{y}=-3.3m[/tex]
since we're vertical.
Solve for [tex]v[/tex].
