Computing Fourier Series for x^2 Between -pi and pi
The discussion focuses on computing the Fourier series for the function x^2 over the interval from -π to π. The user successfully calculates the coefficient a_0 as π²/3 but struggles with the a_n coefficients, which require integration by parts twice. The final result for a_n simplifies to (-1)^n * 4/n², with b_n being zero due to the even function multiplied by an odd function. Clarifications are made regarding the behavior of sine and cosine functions at integer multiples of π. The thread emphasizes the importance of using Wolfram Alpha for verification and simplification of the results.
Studious_stud
Equations to compute Fourier series given in question
Ok so I've just done this problem and I'm having some trouble computing the Fourier series of x^{2} between -∏ < ∏
So first I calculate a_{0} and that turns out to be \frac{∏^{2}}{3}, which according to wolfram is right.
Next a_{n}, which is the one I'm having trouble with. Essentially you have to do integration by parts twice (right?) and I end up getting something quite messy, as does wolfram
http://www.wolframalpha.com/input/?i=integrate+x^2+cos+%28n+x%29+dx+from+x%3D-pi+to+pi
Is there any way to clean this up for when I plug a_{n} into the final formula?
b_{n} is 0 obviously so there's no issue there (since it's an even function times an odd function).
Thanks in advance everyone. :)
You should find it simplifies down to a_n = (-1)^n\frac{4}{n^2}. Since you know n is an integer, you should find some terms vanish, etc.
You can get the answer from Wolfram Alpha by entering "FourierTrigSeries[x^2, x, 10]".
Thanks for the response.
So let me get this right... cosn∏ = (-1)^n and sinn∏ = (-1)^n?
Sorry still a bit confused!
Not quite. You might want to take a look at a plot of the trig functions.
Whoops, meant to say sinn∏=0, is this correct?
Yes, that's right.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
