Calculating Halley's Comet Speed at Maximum Distance
29 replies · 10K views · last reply
physicsgurl12
As Halley’s comet orbits the sun, its distance from the sun changes dramatically, from 88700000000 m to 5614000000000 m. If the comet’s speed at closest approach is 53430 m/s, what is its speed when it is farthest from the sun if angular momentum is conserved?
v=d/t ? i have no clue where to begin.
my attempt was usless. i don't even know a formula to use.
welcome to pf!
hi physicsgurl12! welcome to pf! :smile:
what is its angular momentum at closest approach (call its mass "m", and assume it's a point mass)? :wink:
Hi Physicsgurl12, welcome to PF! :smile:
The relevant equation you need, is conservation of angular momentum L.
That is:
L = mvr
where v is the speed perpendicular to a distance r from the sun, and m is the mass of Halley's comet.
Can you set up an equation that equates the angular momentum at the closest point to the sun to the angular momentum at the farthest point to the sun?
Note that at closest approach and furthest from the Sun that the comet is at either end of its elliptical orbit. At those times, what can be said about the relative orientations of the velocity and radius vectors? Can you write formulae for the magnitude of the angular momentum (or specific angular momentum) at those points?
  • Diagram of an elongated elliptical orbit with a yellow Sun at the left focus. Left label: r1 = 8.87 x 10^10 m, v1 = 53430 m/s, with a downward arrow at the near end. Right label: r2 = 5.614 x 10^12 m, v2 = ?, with an upward arrow at the far end.
this helps but i don't know how to fill in the equation using the numbers i have.
At the closest point you have a distance r = 88700000000 m
And you have a speed v = 53430 m/s
Since the comet is at its closest point to the sun, its speed will be perpendicular to its distance, which is what we need.
Furthermore we have an unknown mass m, which we will just leave as "m" for now.
Can you calculate the angular momentum L in this case?
Do you have both the distance and speed at a point in the orbit where the velocity is perpendicular to the radius vector?
uh no, because we don't know M??
could you just post how you would solve it. i think that would help me understand better.?
That's ok, so L will be some factor that you can calculate times "m".
Can you say what this factor is?
please read the forum rules
please attempt the question yourself
what is the angular momentum at closest approach (call the mass "m", and assume it's a point mass)?
i can't attempt the problem if you can't tell me how to start it. We just started this chapter and its an honors class so there's not a lot of help. so mabey if you explain how to do like the first 2 steps i could go from there.
honestly i don't know what that "factor" is. also I am super confused on how you CAN calculate times m.
We are really trying to help you here. Please believe me.
We are trying to explain how to do the first step.
The first step is taking the formula
[tex]L = m \times v \times r[/tex]
and replacing as many symbols as you can by the numbers you know.
In my previous post I've already written what these numbers are.
[edit] "factor" is the word for a number with which you multiply. In this formula for instance "v" is a factor. [/edit]
As the other posters have tried to explain, that's not how Homework Help works here at the PF. You have been given some great turorial help so far -- please try to use it and start writing out some equations to see where you get...
You should also consider doing a bit of reading at websites like wikipedia.org to get more background information. You could try search terms like orbital mechanics, for example :wink:
okay well i understand that i can fill in r with 88700000000 and v with 53430 but i don't understand what you want me to do from here. arnt we looking for l? and i don't know the mass so i can't fill that in either?
Does looking over the wikipedia page that I suggested help your understanding?
Could you please write that down in the formula?
And could you multiply the numbers for v and for r?
The next step is to do the same for the farthest distance.
i understand why you would say that's not how it works, but mabey you should think about how others not just yourself. what i mean is that everyone learns in a different way. some people learn by seeing something done, some are more hands on and some can just listen to something being explained and get it. but i am not one of those people. i myself am a visual person. also i have tryed wikipedia and the advanced vocabulary it uses to explain things ,like many sites, are hard to comprehend.
L=(4.739241*10^15)*m
so for the next step i do the exact same thing but change the r to 5614000000000??
[Hijack]
I understand your point, but this thread in the Feedback forum should help you understand why we have the rules the way that we do:
https://www.physicsforums.com/showthread.php?t=373889
[/Hijack]
Now L and m are constant, so what is v at the furthest point?
[Hijack]
[/Hijack]
i totally get the rules you have but this perticular assignment is online, everyones problems are different and we had a sub today so we couldn't ask questions on how to do any of the worksheet. mabey, just mabey you should trust people a bit more. i mean the kids who are taking physics especially when its honors or not a required class most of those kids arnt going to be the ones are going to cheat.
That's fine! :smile:
Yes and no.
Yes, you need to do the exact same with r is 5614000000000, but you do not know the speed v at the farthest distance yet, so you need to leave v as it is.
Could you write that down again please?
The next step is to say that the two results for L are equal to each other.
isnt it 5614000000000?
Yes and no.
so L=m*(4.739241*10^15) and L=mv5614000000000
then m*94.7392441*10^15)=mv5614000000000 tthen m cancles out and then you get v=844.1825793 m/s?
Yep! You've got it! :smile:
i entered it and it said it was correct. thanks so much. now i understand what you were trying to say earlier.
You're welcome. :)
I'm glad we got it cleared up.
