Calculating Heat Absorbed & Estimating Power Rating of Electric Heater
The discussion revolves around calculating the heat absorbed by air passing over an electric heater and estimating the heater's power rating. The initial calculations yielded incorrect results due to a misunderstanding of the density of air, which should be 1.2 kg/m³ instead of kg/cm³. The correct formulas were used, but unit conversions were not properly applied, leading to a significant overestimation of power at 60 MW instead of the correct 60 W. Participants emphasized the importance of accurate unit conversions and highlighted the discrepancies in the provided materials. Ultimately, the correct calculations clarified the misunderstanding and confirmed the book's answers.
KevinO
the question states exactly:
Air passes over an electric heater at a steady rate of 2500 cubic centimeters per second. the steady inlet flow temperature of the air is 20 degree celcius and the steady outlet temperature is 40 degree celcius.
part a. what is the heat absorbed by the air passsing over the heater in 2 hours
part b. obtain an estimate power rating of the heater. is this too high or too low? explain.
[density of air = 1.2kg/cm^3; specific heat capacity of air= 1000Jkgcm^-3]
the equations i used were P=E/t; E=mcΔθ; ρ=m/V
for part a: After some substitutions i said P= (ρVcΔθ)/(t) where V/t = 2500cm^3s^-1
then i multiply my answer from that by 7200seconds and said that was the heat absorbed.
for part b: i just took the answer from P= (ρVcΔθ)/(t) and said that was the estimated power rating. my answers were P= 60MW and E=4.32 × 10^11 J
the text however says the answer was P= 60W and E=4.32×10^5 J. i assumed my answer was correct and the book had a mistake. when i showed my teacher however she said it was wrong to try again but i stuck.
Hello KevinO. Welcome to Physics Forums.
The units attached to the specific heat capacity for air look mighty suspicious. Should be J/(K*kg) I'd think.
I think it would be helpful if you were to expand on that ad show more details of your work. Could be you've got a problem with unit conversions...
Yup, the books answers look okay to me, too.
thank you for the welcome:
Yes the units for it was suppose to be J/(K*kg)
my solution was:
P=ρVc∆θ/t=[1.2kg/(cm^3)×2500cm^3×1000J/(kg*K)×20K]/1s=6.0×10^7 J/(s)
P*t= E = 6.0×10^7 J/s × 7200s = 4.32×10^11 J
Okay, your density for air is not correct (I should have spotted that earlier). If air had a mass of 1.2 kg for every cubic centimeter (about the size of a sugar cube), we'd be swimming, not walking!
The density of air should be 1.2 kg per cubic meter :wink:
Thank you it works out great now.I checked the book to make sure i did not type the units wrong but the book has it with the wrong units. She should have point that out though instead of making me frustrated thinking i doing something wrong. thanks again.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
