Calculating Heat Balance & Steam kg/kg for Different Variables
The discussion revolves around calculating the steam kg/kg in a heat balance context, specifically regarding an experiment involving entering and exiting steam temperatures and pressures from an evaporator. The original poster presents four scenarios with varying steam and water conditions, seeking to understand the calculations involved.
  • The original poster attempts to use steam tables and formulas to calculate steam kg/kg but encounters difficulties, particularly with negative results and the role of temperature in the calculations. Some participants question the intended setup of the entering and exiting conditions, suggesting that the original poster may have reversed them.
Participants are actively engaging with the original poster's queries, providing insights into the nature of the calculations and the assumptions involved. There is a recognition of potential confusion regarding the pressure changes and the definition of a flash process. The discussion is ongoing, with clarifications being sought and provided.
The original poster notes a lack of clarity in their calculations and expresses uncertainty about the implications of temperature changes on their results. There is also mention of using a specific steam table for reference, which may influence the accuracy of the calculations.
maarjaaur
Hello,
Im new here, sorry for my english, but I am in desperate need of help regarding my own experiment which i need to finish. I need to calculate steam kg/kg (flash steam maybe in english?). Basically i have entering steam temperature and pressure and exiting steam temp. and pressure from evaporator? and i need to find ... S/W... kg/kg
I need to find basically 4 different answers all with different entering steam/water variables.
1) entering temp 100 Celsius,1atm. exiting 100C 2atm.
2)entering temp 15C, 1atm. exiting 100C 2 atm.
3)entering 0,8atm 100C. exiting 100C 2atm.
4) 15c 0,8 atm. exiting 100C 2atm.
I have tried according to these calculations but something doesn't add up.
I take info from a table where i get kJ for water at different pressure but i don't understand how does temperature change the calculations. And i get minus answer for the first variable...is it ok?
example at 1. variable
I take the formule given above and fill the blanks with steam table here: http://www.engineeringtoolbox.com/saturated-steam-properties-d_101.html
then i get minus answer and i think its false, i don't know where to calculate the temperature i have only taken the pressure and kJ-s from the table into account according to that formula. ( 417,5-504,7 / 2201,59 = - 0,0396 kg/kg )
Hello Maar, and welcome to PF. Your essay is indeed a little difficult to read.
Let's start with 1). Going from 1 atm = 101.325 kPa to 2 atm is a compression, not so much a flash. Is that really intended ? In a flash you decrease the pressure and then it makes sense to calculate how much vapour you get per kilogram water coming in.
This repeats in the other three, so I thought I'd better ask.
Hey,
Probably yeah, you are right and the entering/exiting temp and pressure is in reverse. Will edit in main post.
Ok, can't change so... please see entering/exiting variables in reverse. I myself also noted that it is a bit unlogical that way.
OK, so we flash 1 kg of water at 100 C 2 x 101.33 kPa to 1 kg of water liquid + water vapour at 100 C, 101.33 kPa and want to know the mass of the water vapour.
Relevant equations: mass conservation and enthalpy conservation (assuming the flash is adiabatic: no energy is added or removed).
mass conservation: ##m_{\rm water \ in} = m_{\rm water\ out} + m_{\rm steam \ out}##
enthalpy balance: ##m_{\rm water\ in} H_{\rm water\ in} = m_{\rm water\ out}H_{\rm water\ out} + m_{\rm steam\ out}H_{\rm\ steam \ out}##
Per kilogram of water in, defining x = ## m_{\rm steam \ out}/ m_{\rm water \ in} ## :
## H_{\rm water\ in} =(1-x) H_{\rm water\ out} + x H_{\rm\ steam \ out} \ \Leftrightarrow##
## H_{\rm water\ in}- H_{\rm water\ out} = x ( H_{\rm\ steam \ out}- H_{\rm water\ out}) \ \Leftrightarrow##
$$x = { H_{\rm water\ in} - H_{\rm water\ out} \over H_{\rm\ steam \ out}- H_{\rm water\ out}}$$
