Calculating Horizontal Distance for a Falling Object Without an Angle
  • Thread starter Thread starter red1312
    Kinematic
The problem involves calculating the horizontal distance a book travels after being shoved off a table, where the book falls from a height of 1.2 m with an initial horizontal acceleration of 1.3 m/s². The discussion centers around the lack of an angle in the problem setup.
  • Participants discuss breaking the problem into horizontal and vertical motion components. Questions arise regarding the appropriate formulas to use for calculating time and horizontal distance, as well as the implications of starting with zero vertical velocity.
Some participants have offered guidance on how to approach the problem by calculating time to hit the ground and horizontal distance. There are differing calculations regarding the time it takes for the book to fall, indicating an ongoing exploration of the problem.
Participants note that the initial vertical velocity is zero and question the assumptions made about the time of fall and the formulas used in the calculations. There is a focus on ensuring the correct interpretation of the motion components involved.
red1312
A girl shoves a book at rest on a table and it moves with an acceleration of 1.3 m/s . After 5 s, the book falls at the edge of the table. If the table height is 1.2 m, find the horizontal distance that it hit the floor. (ans: 3.22 m) ... How the answer would be 3.22
Actually in this question doesn't have the angle .. So is it right to choose the maximum height formula so I can have the angle and then apply the Horizonte distance which is v0^2 sin2(q)/g
Tq
I would break the problem into two parts, horizontal and vertical motion.
You know the height and the initial vertical velocity. How long in seconds does it take to hit the ground?
Calculate the horizontal velocity. How far does it travel horizontally in the same time?
The angle is simply zero cause the velocity of the book, just before it starts falling, is horizontal.
Which formula for both parts ?
Yeah ..I just solve it thank so much
First we find the velocity from this formula v=at
Then we apply to find the time that it take to hit the ground which from this formula y=y0+v0y(t)+(1/2)gt^2
Finally we just multiply between the velocity from the answer 1 (6.5) and time 0.16
Is it right ??
well yes and no. The time it takes from the moment it passes the edge of table to the moment it hits the ground isn't 0.16 according to my calculations. Just use h=(1/2)gt2
Ooh so the time will be 0.49 s
Sorry
yes but still you have to understand something, when you wrote the equation for y, [itex]y=y_0+v_{0y}t+(1/2)gt^2[/itex] it is [itex]v_{0y}=0[/itex] cause the book starts its fall with only horizontal velocity component.
  • · Replies 38 ·
  • · Replies 23 ·
10K
