Calculating induced drag on Tapered Wing
15 replies · 6K views · last reply
ChimM
When Cl = 0.9, find the difference in induced drag for a rectangular wing of 36-ft. span and 6-ft. chord and a tapered wing of the same area, the tapered wing having a 6-ft. chord at the root, the leading and trailing edges being tangent to a circle of 2-ft. radius at the tip, and the fuselage being 3 ft. wide. The airspeed is 100 miles
per hour.
---From that question, I have been able to calculate the induced drag for the rectangular wing. How can I solve the average chord of the tapered wing by this,"the tapered wing having a 6-ft. chord at the root, the leading and trailing edges being tangent to a circle of 2-ft. radius at the tip, and the fuselage being 3 ft. wide".
Please help.. Thank you.
per hour.
Well, making a sketch of the wing layout would be a big help here.
You are given the wing span, the width of the fuselage (the thingy in the middle to which the wings are attached), and the width of the root chord.
The layout of the wing tips is a little trickier, but basically, on your sketch, lay out a circle of radius = 2 feet such that the center of the circle lies at the mid-chord line of the wing plan. The leading and trailing edges of the wing will connect the ends of the root chord and be tangent to this circle.
The layout of the wing tips is a little trickier, but basically, on your sketch, lay out a circle of radius = 2 feet such that the center of the circle lies at the mid-chord line of the wing plan. The leading and trailing edges of the wing will connect the ends of the root chord and be tangent to this circle.[/QUOTE
I'm still confused. Am I doing it right? Attached here is the illustration of the given data.
Hoping for your kind clarifications.. Thank you..
I'm still confused. Am I doing it right? Manually, how can compute for it. Attached here is the illustration of the given data.
  • Diagram of a wing planform inside a circular fuselage cross-section between two hatched boundaries; red vertical line labelled Fuselage Width, blue horizontal line labelled Root Chord, green horizontal line labelled Tip Chord, with the wing outline tapering from root to tip.
It's clear from your diagram that you are having trouble understanding how an airplane looks in plan view.
The fuselage is the body of the airplane, which is occupied by passengers and/or cargo. It's the structure to which the wings are attached. In other words, the wings stick out from the sides of the fuselage.
The wingspan is the total distance measured from wing tip to wing tip, and this distance runs perpendicular to the centerline of the fuselage.
This diagram might help envision the wing layout rather than using wordy explanations:
Wing area diagram with three plan-view wing shapes: constant-chord with span s and chord c, giving A = s x c; tapered with span s, tip chord Tc and root chord Rc, giving A = s(Tc + Rc)/2; and a combined planform with spans s1 and s2, giving A = (s1 x Rc) + s2(Tc + Rc).
Instead of having the wing tips squared off as shown in the diagram above, lay out a circle of radius = 2 feet such that the center of the circle lies at the mid-chord line of the wing plan. The leading and trailing edges of the wing will connect the ends of the root chord and be tangent to this circle. You could probably use a lot of math to calculate these intersections, but making a simple sketch to scale on a piece of paper would be quicker and more accurate.
Diagram of wing area formulas for three planforms: constant-chord A = s x c, tapered A = s (Tc + Rc)/2, and combined sections A = (s1 x Rc) + s2 (Tc + Rc), with labelled span, chord, tip chord and root chord.
Thanks a lot! I got the answer! :)
Hi, I'm here again. I have been able to solve the problem by using AutoCAD. I also searched for computations and calculations of the chord created by the tangential lines, unfortunately, i haven't seen any. Please help me to solve the chord at the tip :(
You didn't mention what formula(s) you're using to calculate induced drag. The formula is probably simplified to ignore issues like tip and trailing edge vortices.
Di = [(Coefficient of lift)^2 (density at SSLC/2) (span) (velocity in ft/s)^2] / (pi x AR)
Wherein AR = b/c
For tapered wing, (Root chord + tip chord) / 2
I'm having a hard time to calculate for the tip chord.[/SUB][/SUB]
Hint - one way to calculate average chord length is to divide the area of a section by it's span.
But, on the tapered, there's no given data for span :(
ChimM said:
But, on the tapered, there's no given data for span.
The problem states that the tapered wing has the same area as the rectangular wing, so the total area is known. You also know that the root is 6 feet, the tip is 4 feet, with a 2 foot radius semi-circle attached to each tip. You can calculate the area of a semi circle based on it's 2 foot radius. Then subtract that from the total area (per wing), to get the area for the trapezoid portion of the wing, then use the formula for trapezoid area to get the span of the trapezoid portion of each wing. Then the total span for each wing equals the trapezoid portion plus the 2 foot radius of the semi-circle at the wing tip.
Wow! Thanks for that! I got it. I was confused for the usage of the given data about the fuselage. Anyway, I used 3.82 instead of 4 for the tip of the chord. Because of the tangential line. Is that okay? But the area of the circle will also change. Do I need to stick with 4ft tip?
Here is my solution:
Wing area = 216
Root chord = 6
Tip chord = 3.82
Area of the sector = 7.4814
Area of trapezoid = 216 - 7.4814 = 208.5186
Altitude of the trapezoid as the wing span = 42.3625 + 2 ft radius = 44.3625
THANKSSSS! :)
The problem states it's a 2 foot radius circle. It doesn't state how the wing tapers, so you could assume it tapers equally from the leading and trailing edges, so the chord at the base of the semi-circle would be 4 feet. Normally, a "wing span" includes the diameter of the fuselage, but the wing area does not.
Okay. Thanks for the information :)
Hmm, one more thing.
Aspect ratio = wing span / chord or Aspect ratio = wing span ^2 / wing area
Which do I need to use in terms of exact computation? Because using both computation has a minimal difference on Drag. But for the computation of Coefficient of induced Drag, difference in decimal value matters.
Coefficient of induced Drag = (coefficient of lift)^2 / (pi x AR)
ChimM said:
Aspect ratio = wing_span / average_chord or Aspect ratio = wing_span ^2 / wing_area
These are the same:
AR = wing_span^2 / wing_area = wing_span^2 / (wing_span x average_chord) = wing_span / average_chord
It's not clear how the problem wants you to take the fuselage into account.
rcgldr said:
These are the same:
It seems that the given data about fuselage was at the problem for confusion. Thanks a lot sir! :)
