:Calculating $k$ to Find Wire Length
  • Context:
  • Thread starter Thread starter karush
    Length Wire
5 replies · 2K views
karush
MHB
$\tiny{2.5.1}$
Electrical Resistance of a Wire
The electrical resistance of a wire varies directly with the length of the wire and inversely with the square of the diameter of the wire.
If a wire 432 feet long and 4 mm in diameter has a resistance of 1.24 $\Omega$
find the length of a wire of the same material whose resistance is 1.44 $\Omega$ and whose diameter is 3 mm
y varies inversely with x $\quad y=\dfrac{k}{x}$
y varies directly with x $\quad y=kx$
OK not real sure how to set this up think we need to get the value of $k$ first
yes,
$1.24 = k \dfrac{L}{d^2}=k \dfrac{432}{(4)^2}$
$k=0.04592$
so far hopefully
added to Google calendar
$k=0.04592$
so far hopefully
Units! (They are really weird units.) This is a Physics problem. All quantities with units must be stated with what they are.
So far so good. So use [math]R = k \dfrac{L}{d^2}[/math] again to find R.
-Dan
karush said:
$\tiny{2.5.1}$
Do you understand that you need ONE equation, not two? And of course you don't want to use "x" for both length and diameter.
Letting "R" be electrical resistance", L be the length, and D the diameter of the wire, since R varie directly with L and inversely with the square D,
$R= k\frac{L}{D^2}$.
Now, yes, you need to find k. For that you need to know every thing except k.
You are told "a wire 432 feet long and 4 mm in diameter has a resistance of 1.24 Ω".
So $1.24= k\frac{432}{4^2}$. Solve that for k.
