Calculating Kinetic Energy, Velocity and Height for a .5kg Ball
The discussion revolves around calculating the kinetic energy, initial velocity, and velocity at a specific height for a 0.5 kg ball thrown to a height of 20 meters. The kinetic energy is calculated using the formula KE = 1/2mv^2, with the final velocity at maximum height being 0 m/s. The user initially misunderstands the initial velocity but later correctly calculates the final velocity using the equation Vf^2 = 0 + 2(9.81)(20m), resulting in a velocity of 19.8 m/s. This leads to a kinetic energy of 98.1 Joules. The user questions whether the initial velocity is zero, indicating some confusion about the concepts involved.
KatieLynn
If a .5kg ball is thrown up in the air and reaches a height of 20 meters.
A)What is the ball's Kinetic Energy?
B)What is its initial velocity, as it leaves the thrower's hand?
C)What is its velocity at 16 meters?
KE=1/2mv^2
Okay so for the first one I'm thinking I need to use KE=1/2mv^2, I have the mass but I need the velocity to solve for the kinetic energy. So then I thought maybe the velocity would just be 0 because it says "as it leaves the thrower's hand" as in the split second when its not moving?
Use v^2=u^2+2as. At max height(which I believe to be 20m) the final speed=0
what do u and s stand for in that equation?
u=initial speed,s=displacement,v=final speed,a=acceleration
Shouldn't it be ... ?
v_y^2=v_{0y}^2-2g\Delta y
LOL, I had this posted till you replied with that mgh thing, and since I don't know that much Physics I was like wow I'm totally off.
Okay here's what I did using that equation...
Vf^2= 0 + 2(9.81)(20m)
Vf=19.8m/s
then KE=1/2mv^2
so 1/2(.5kg)(19.8m/s)^2
KE=98.1
Correct?
Now would B just simply be 0?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
