estro
- 239
Hi,
I'm trying to calculate some line integral with both Gauss' and Stokes' theorems, but for some strange reasons I get different results. Since the solution with Stokes' theorem seems to be somewhat easy I doubt that this question was meant to be solved by Gauss' theorem but I still want to try.
Setting the stage:
Let C be a curve which is the intersection of a ball x^2+y^2+z^2=a^2 and a plain x-y+z=0.
F is a vector field defined by: \mathbf{F} = (y-2z,x-z,2x-y).
The "wanted" line integral is: \int_C \mathbf{F} \centerdot d \mathbf{x} [the orientation doesn't matter since I only interested in absolute numerical value.].
As the intersecting plane has the origin in it and since the center of the ball is the origin as well we can conclude that the plain slices the ball into 2 equal pieces and the curve cuts the ball surface into 2 surfaces with equal area. I will denote S for the whole surface of the ball and S1, S2 for its 2 equal halfes. I will denote the flat surface between the 2 half of the ball with H.
I calculate and get \nabla \times \mathbf{F}=(0,-4,0)
Calculation using Stokes' theorem:
\int_C \mathbf{F} \centerdot d \mathbf{x} = \iint_{H} (\nabla \times \mathbf{F}) \centerdot \mathbf{n} ds = \iint_{H} (0,-4,0) \centerdot \frac{(1,-1,1)}{\sqrt{3}}ds= \frac {4} {\sqrt{3}} \iint_{H}ds= \frac {4} {\sqrt{3}} \pi a^2
The last surface integral is exactly the surface of H which is a surface of a cycle with a radius of 'a' and this explains the last transition at the above equation.
To conclude:
\int_C \mathbf{F} \centerdot d \mathbf{x} = \frac{4} {\sqrt{3}} \pi a^2
Calculating using the Gauss' theorem:
Since Stokes' theorem states that only the boundary of the a surface plays the role I can conclude that:
\int_C \mathbf{F} \centerdot d \mathbf{x} = \iint_{S_1} (\nabla \times \mathbf{F}) \centerdot \mathbf{n} ds and \int_C \mathbf{F} \centerdot d \mathbf{x} = \iint_{S_S} (\nabla \times \mathbf{F}) \centerdot \mathbf{n} ds, and since both share the boundary:
2\int_C \mathbf{F} \centerdot d \mathbf{x} = \iint_{S_1} (\nabla \times \mathbf{F}) \centerdot \mathbf{n} ds + \iint_{S_2} (\nabla \times \mathbf{F}) \centerdot \mathbf{n} ds=\iint_{S} (\nabla \times \mathbf{F}) \centerdot \mathbf{n} ds
And I apply the Gauss' theorem:
\iint_{S} (\nabla \times \mathbf{F}) \centerdot \mathbf{n} ds=\iint_{S} (0,-4,0) \centerdot \mathbf{n} ds=\iiint_{x^2+y^2+z^2\leq a^2} \nabla \centerdot (0,-4,0)dxdydz=0So I get a different answer which means somewhere I did a mistake however I checked myself a million times and I'm sure I did not commit computational mistake and my mistake must be conceptual.
I will appreciate help, thanks in advance.
EDIT: I just fixed many errors and typos I found in my question... [Thanks to Fractal20 for spotting one of them.]
Setting the stage:
To conclude:
