Calculating Magnetic Field Intensity Between Two Parallel Wires
14 replies · 10K views · last reply
Winzer
Two long parallel wires are a center-to-center distance of 1.50 cm apart and carry equal anti-parallel currents of 1.80 A. Find the magnetic field intensity at the point P which is equidistant from the wires. (R = 4.00 cm).
[tex]B= \frac{u_{0}I}{2\pi r}[/tex] infinite wire
Ok I have been workin this problem for a while.
In terms of vectors, the y's cancel out.
For the X direction I get:
[tex]B_{totalx}=\frac{u_{0} I R}{\pi \sqrt( (d/2)^2 +R^2)}[/tex]
I don't get why I am wrong, I took the sum of the b-fields in terms of vectors.
And no the answer is not 0 T!
  • Diagram of two long parallel wires in cross-section: one with current out of the page shown as a dot, one with current into the page shown as a cross, separated by distance d vertically; point P lies to the right at horizontal distance R from the wires, with R marked as a horizontal arrow and d as a vertical arrow.
Why do you think that the Magnetic field is not zero?
Thats what I thought originally , but it is incorrect.
If they have equal, anti-parallel currents, and it's a point that's equidistance from the wires, then the answer has to be zero. Unless you decide to ignore the fact that magnetic fields are vectors.
Thats what I used to think too, but when I entered 0 T it is incorrect.
there is something else I am missing.
Go back and ask your instructor what he means by anti-parallel. It has more than one meaning. It shouldn't but it does.
I agree, word choice could be better.
However I don't have contact with my prof. right now, this assignment is due in an hour.
If I was you I would give your best guess (ignore that you know it's "not right") and argue for points later. Chances are others having the same problem.
perhaps his answer is wrong by mistake? talk to other people in the class
he is not, there is an answer I people got. There is some trick though, but my math tells me otherwise,
? The two B fields add up, they don't cancel!
It's when the currents are in the same direction that the total B field is zero at the point midway between them.
Good.
True.
Show how you got that answer--it's not dimensionally correct, for one.
OK, now that I can see your diagram, I see the instructor used anti-parallel in the correct sense.
