Calculating Magnetic Force on Ferrofluids Between Two Magnets
3 replies · 4K views · last reply
Flashlight21
I have the problem that I want to calculate the force of a magnet acting on a ferrofluid. I know this is is difficult but I am trying to make some simulations of physical behavior on ferrofluids
Consider a U-shaped magnet with ferrofluid between the two poles. The distance between the poles will be in the order of 1mm and this gap will be completely filled with fluid. Now I would like to calculate the force the magnet exerts on the ferrofluid. Now I know that the magnetic field strength between the poles is around 0.8Tesla.
I found the following formula:
F=B2*A/(mu0*2)
where:
F: is the force between the two nearby surfaces [N]
B: is the magnetic field strength [T]
A: is the contact area between the surfaces [m2]
mu0: is the magnetic permeability constant 4*pi*10-7
The problem is that I do not know whether this formula is correct or not and if it is correct how can I use this the calculate the force since this formula is only for two magnetized surfaces. Also this formula only calculates the force perpendicular to the surface and eventually I would have to expand to the force parallel to the magnets surfaces.
Thanks in advance
Flashlight
PS. if I did not make myself clear please tell me and I will expand on the problem
Any progress on this? I'm playing around with ferrofluid myself and want to be able to suspend it in a tube.
Cheers,
Dave
Cheers,
Dave
Welcome to the PF, Dave.
From the poster's Profile page:
Flashlight21 was last seen: Apr 6, 2011
You probably won't be getting a response from him, but maybe somebody else can help you out with your question... :smile:
Alright, I'll try making a post.
