Calculating minimum velocity around a loop
Nouo
So I had this question for physics about something going around a loop. The question asked what the minimum velocity to counteract gravity is if something is going around a loop. hint: One force will be zero.
I'm not sure how to figure this out, can someone help?
Mathematics news on Phys.org
Can you calculate the centripetal acceleration of a particle moving at some velocity around the loop? You can assume the loop is of radius r and treat it as a constant.
If an object is going around a loop of radius R at constant angular velocity, [itex]\omega[/itex] then its position vector (taking center of the loop to be (0, 0) and the objects position at t= 0 to be (1, 0)) is [itex]R cos(\omega t)\vec{i}+ R sin(\omega t)\vec{j}[/itex]. Its velocity vector will be [itex]-\omega R sin(\omega t)\vec{i}+ \omega R cos(\omega t)\vec{j}[/itex] and its acceleration vector will be [itex]-\omega^2 R cos(\omega t)\vec{i}- \omega^2 R sin(\omega t)\vec{j}[/itex]. In order to stay on the loop, the acceleration at the top ([itex]\theta= \pi/4[/itex]) must be non-negative.
