Calculating Moment: Addition of Torque Components
  • Thread starter Thread starter Saptarshi Sarkar
    Addition Moment
3 replies · 2K views
Saptarshi Sarkar
In order to pull out the nail at B, as shown in the figure, the force F exerted on the handle of the hammer must produce a clockwise moment of 500 lb-in about point A. Determine the required magnitude of force F.
##T=F\times l##
First of all, sorry for the units. This is a problem I found on the internet and am confused about the solution.
I calculated the two components of the moment (torque) to be
##T_x = 18\times Fcos(30)## and ##T_y=5\times Fsin(30)##
The problem is, I got the proper answer (the two options were 27.64 lb and 55.28 lb) by direct addition of the two components but did not get it by vector addition (for magnitude).
I am not sure how I got the correct answer using a seemingly incorrect method.
The torque vector is the cross product of the force vector and the lever arm vector. So what direction is it in?
Solution #1 is correct because both components of F (x and y) are perpendicular to the lever of each respect to the point A, where the moment said to be applied.
Solution #2 is incorrect because you are mixing torque with your effort to determine F from its x and y components.
Got it. Both of the them are pointing in the same direction, so it should be added normally. Thanks!
