Calculating Momentum of a 50g Bullet: Need Help?
The discussion revolves around calculating the momentum of a 50g bullet given its kinetic energy of 250J. The subject area is primarily focused on momentum and kinetic energy in physics.
  • Participants explore how to derive the velocity from the given kinetic energy and mass. There are inquiries about the definitions and formulas related to kinetic energy and momentum, with some participants questioning the completeness of the information provided.
The discussion is active with participants attempting to clarify the relationship between kinetic energy and momentum. Some guidance has been offered regarding the definitions of kinetic energy and momentum, but there is no explicit consensus on how to proceed with the calculations.
Participants note the absence of certain definitions or formulas that might aid in solving the problem, and there is a suggestion to refer to lecture notes or external resources for additional information.
Recce
(Mentor's Note: Thread moved from general physics after being replied to, hence the lack of a template)
Find the momentum of a 50g bullet whose kinetic energy is 250J.
I know the formula to find momentum is P= mv. Please give me hints
Can you find "v" from what you've been given?
No, the question only gave me 50 g bullet and 250J
You have been given a definition/formula for kinetic energy?
Th
The formula the teacher gave are p=mv and FT= delta P
Recce said:
p=mv
This is the definition of momentum, and you've indicated you understand it.
Recce said:
FT= delta P
"Force x time (which is impulse) equals change in momentum." The bullet before it is fired has zero velocity and zero momentum. The change in momentum then is just "mv" from the first definition. So, all you need to find now is force and time.
Are you absolutely certain you haven't been given any other definitions or formulas for kinetic energy, force, mass, work?
No
Kinetic energy is defined as Ek = mv2/2 . I cannot believe that you haven't seen this in class or in the teaching materials or textbooks before being asked the original question.
Recce said:
No
The problem gives mass and kinetic energy.
You should know what kinetic energy is. Look after in your lecture notes. Or you can browse the Net. See, for example: http://www.physicsclassroom.com/class/energy/u5l1c.cfm
(Attached image removed by moderator, provided the answer to the OPs homework question.)
Örsan Yüksek
Correct!
  • · Replies 71 ·
  • · Replies 31 ·
  • · Replies 29 ·
