Calculating <p>_c for Charge-Conjugated Dirac Spinor
  • Level: Graduate
  • Thread starter Thread starter qinglong.1397
10 replies · 3K views · last reply
qinglong.1397
I calculated the expectation value of the momentum of the charge-conjugated Dirac spinor and found that it was the negative of that of the Dirac spinor. Here is the calculation.
Charge conjugation operator is chosen to be [itex]C=i\gamma^0\gamma^2[/itex]. The spinor is [itex]\Psi[/itex] and its charge-conjugated spinor [itex]\Psi_C=-i\gamma^2\Psi^*[/itex].
The expectation value of the momentum of [itex]\Psi_C=-i\gamma^2\Psi^*[/itex] is given by
[itex]<\vec p>_C=\int d^3x\bar\Psi_C\vec p\Psi_C=\int d^3x\Psi^T\gamma^0\gamma^2\vec p\gamma^2\Psi^*=-[\int d^3x\bar\Psi\vec p^*\Psi]^*[/itex]
[itex]=[\int d^3x\bar\Psi\vec p\Psi]^*=<\vec p>^*=<\vec p>[/itex]
where [itex]<\vec p>[/itex] is real.
Is there anything wrong with my calculation, because my teacher didn't give me the grade for this?
I guess my calculation is correct since nobody replies...
It's hard to tell from what you have written. Did you remember that p acts to the right, and when you switch it from acting on one ψ to the other, you have to integrate by parts?
I did use integration by parts.
What does [itex]\Psi^{\ast}[/itex] represent?
I'm just thinking that jμ does change sign while pμ does not, and the only difference between them is the derivative operator.
By [itex]j_\mu[/itex], do you mean electric current?
Actually, I found out that [itex]<\vec r>_C=-<\vec r>[/itex] and my teacher also got this.
I think there is a mistake in your calculation. If [itex]{{\Psi }_{C}}=-i{{\gamma }^{2}}{{\Psi }^{*}}[/itex] then [itex]\Psi _{C}^{\dagger }=i{{\Psi }^{T}}{{\gamma }^{2}}^{\dagger }=-i{{\Psi }^{T}}{{\gamma }^{2}}[/itex] since [itex]{{\gamma }^{2}}^{\dagger }=-{{\gamma }^{2}}[/itex]. Then:
[itex]\begin{align}<br /> & {{\left\langle \mathbf{p} \right\rangle }_{C}}=\int{{{d}^{3}}\mathbf{x}\Psi _{C}^{\dagger }\mathbf{p}{{\Psi }_{C}}}=\int{{{d}^{3}}\mathbf{x}\left( -i{{\Psi }^{T}}{{\gamma }^{2}} \right)\mathbf{p}\left( -i{{\gamma }^{2}}{{\Psi }^{*}} \right)}=-\int{{{d}^{3}}\mathbf{x}{{\Psi }^{T}}{{\gamma }^{2}}\mathbf{p}{{\gamma }^{2}}{{\Psi }^{*}}}= \\ <br /> & \quad \quad =-\int{{{d}^{3}}\mathbf{x}{{\Psi }^{T}}\mathbf{p}{{\gamma }^{2}}{{\gamma }^{2}}{{\Psi }^{*}}}=\int{{{d}^{3}}\mathbf{x}{{\Psi }^{T}}\mathbf{p}{{\Psi }^{*}}} \\ <br /> \end{align}[/itex]
since [itex]{{\gamma }^{2}}{{\gamma }^{2}}=-{{I}_{4}}[/itex] . Continuing the calculation we get:
[itex]{{\left\langle \mathbf{p} \right\rangle }_{C}}=\int{{{d}^{3}}\mathbf{x}{{\Psi }^{T}}\mathbf{p}{{\Psi }^{*}}}={{\left( \int{{{d}^{3}}\mathbf{x}{{\Psi }^{\dagger }}\mathbf{p}\Psi } \right)}^{*}}={{\left\langle \mathbf{p} \right\rangle }^{*}}=\left\langle \mathbf{p} \right\rangle[/itex]
since [itex]\left\langle \mathbf{p} \right\rangle[/itex] is real.
Thanks for your reply! Although our results are the same, I still want to point out that you should've used [itex]\bar\Psi_C[/itex] instead of [itex]\Psi^\dagger_C[/itex], otherwise your [itex]<\vec p>_C[/itex] isn't Lorentz covariant.
Of course, my mistake... Let's take a look at this: [itex]\bar{\Psi }[/itex] is defined by [itex]\bar{\Psi }={{\Psi }^{\dagger }}{{\gamma }^{0}}[/itex] and so [itex]\overset{\_\_}{\mathop{\left( {{\Psi }_{C}} \right)}}\,[/itex] will be:
[itex]\overset{\_\_\_}{\mathop{\left( {{\Psi }_{C}} \right)}}\,={{\left( -i{{\gamma }^{2}}{{\Psi }^{*}} \right)}^{\dagger }}{{\gamma }^{0}}=-i{{\Psi }^{T}}{{\gamma }^{2}}{{\gamma }^{0}}=-i{{\Psi }^{T}}{{\gamma }^{0}}{{\gamma }^{0}}{{\gamma }^{2}}{{\gamma }^{0}}=-i{{\left( {{\Psi }^{\dagger }}{{\gamma }^{0}} \right)}^{*}}{{\gamma }^{2}}^{\dagger }=-i{{\bar{\Psi }}^{*}}{{\gamma }^{2}}^{\dagger }[/itex]
Then the integrand of [itex]{{\left\langle \mathbf{p} \right\rangle }_{C}}[/itex] will be:
[itex]\overset{\_\_\_}{\mathop{\left( {{\Psi }_{C}} \right)}}\,\mathbf{p}{{\Psi }_{C}}=-{{\bar{\Psi }}^{*}}{{\gamma }^{2}}^{\dagger }\mathbf{p}{{\gamma }^{2}}{{\Psi }^{*}}=-{{\bar{\Psi }}^{*}}\mathbf{p}{{\Psi }^{*}}=-{{\left( \bar{\Psi }{{\mathbf{p}}^{*}}\Psi \right)}^{*}}={{\left( \bar{\Psi }\mathbf{p}\Psi \right)}^{*}}[/itex]
and so we will get the same mean value. Is this OK ?
Good! I can now discuss it with my teacher. Thanks!
