Calculating P for an Aircraft Flying in a Circular Motion
The discussion revolves around calculating the lift force (P) acting on an aircraft flying in a horizontal circular motion. The aircraft has a mass of 4.00 x 104 kg and maintains a constant speed of 250 m/s while tilted at an angle of 35 degrees to the vertical. The weight (W) of the aircraft is given as 3.92 x 105 N.
  • Mixed
  • Participants express uncertainty about the information needed to solve the problem, with some suggesting that time or radius might be necessary. Others discuss the possibility of using trigonometry to analyze the forces involved.
There is an ongoing exploration of the relationship between the lift force and weight, with some participants proposing equations based on the vertical component of the lift. A few participants have offered algebraic approaches to the problem, while others are still seeking clarification on the necessary steps and information.
Participants are discussing the implications of the forces acting on the aircraft and the need for clarity regarding the problem's requirements. There is mention of a potential second part of the question involving the calculation of the radius.
QuantumNite
An aircraft flies with its wings tilted, in order to fly in a horizontal circle of radius r. The aircraft has mass 4.00 x 104 Kg and has a constant speed of 250ms-1 . with the aircraft flying in this way, two forces are acting on the plane, P [lift] and W [weight which is given as 3.92*105 N] . P is acting at 35 degrees to the vertical. calculate P
centripetal force=mass * velocity2 / radius
centripetal force= mass * angular speed2 * radius
angular speed = theta / time
angular speed = velocity/ radius
angular speed = 2pi * frequency
centripetal acceleration = velocity2 / radius
centripetal acceleration = angular speed2 * radius
Force = mass * acceleration
I can't do it. I swear we need more information. can someone enlighten me.
QuantumNite said:
An aircraft flies with its wings tilted, in order to fly in a horizontal circle of radius r. The aircraft has mass 4.00 x 104 Kg and has a constant speed of 250ms-1 . with the aircraft flying in this way, two forces are acting on the plane, P [lift] and W [weight which is given as 3.92*103 N] . P is acting at 35 degrees to the vertical. calculate P
What information do you think you need?
By the way, I think the weight should be ##3.92*10^5N##. Personally I would do this question algebraically and just plug the numbers in at the end. That's also a good way to work out what quantities you do need.
yes I think that the weight is correct. I couldn't read the sheet correctly.
the info that I think we need : time or radius
I am not sure whether we need to plug it into an equation or just use trig??
You need to think about the forces involved. There's a key equation that will open up the whole problem. And, by equation I mean two quantities that must be equal.
Hint: why doesn't the plan fall out of the sky?
Correct me if I am wrong,
but can I say that the vertical component of P is PCos(35), and it doesn't fall out of the sky because Weight is equal to PCos(35)
Therefore, PCos(35) = 3.92 * 105
So, If we rearrange that equation, P = 3.92*105 / Cos(35) == 321107.6 [1dp]
Yes, that's it exactly. Although, I prefer:
##P = \frac{mg}{\cos \theta}##
or:
##P = \frac{W}{\cos \theta}##
or:
Thanks,
Could you please explain to me how you came to those equations?
QuantumNite said:
Thanks,
I just copied what you had done! I just used letters for the quantities involved instead of plugging in the numbers. There are a lot of advantages to this. Not least, once you plug in the numbers, you lose sight of what is related to what and if you make a mistake, well one number looks very like another, and it is hard to spot an error.
That said, I thought the question was to calculate ##r##. I see now that all you need is ##P##, which is a lot simpler.
Is part 2 of the question to calculate ##r##?
Yes it is.
but I am pretty sure how to do it
F=mv2 / r ,, rearrange for r
QuantumNite said:
Yes it is.
If you post your answer, I can show you the algebraic approach, which might be interesting and/or enlightening!
  • · Replies 28 ·
