Calculating parabola of drooping chain
  • Context: Undergrad
  • Thread starter Thread starter Molydood
    Chain Parabola
The discussion centers on the mathematical analysis of a chain hanging between two posts, forming a catenary rather than a parabola. Key variables include chain tension, weight, and angle. Participants explore the relationship between these variables and the geometry of the problem, ultimately revealing that the solution can be approached without complex formulas by approximating the chain's path as a triangle. The conversation emphasizes the importance of visualizing the problem to arrive at a solution.
  • Understanding of catenary curves and their properties
  • Basic knowledge of calculus for analyzing curves
  • Familiarity with geometry, particularly triangles
  • Concept of tension and weight in physical systems
  • Research the mathematical properties of catenary curves
  • Study calculus applications in physics, particularly in mechanics
  • Explore geometric approximations in problem-solving
  • Learn about tension and weight distribution in chains and cables
Mathematicians, physics students, engineers, and anyone interested in solving geometric problems related to tension and curves.
Molydood
Hi,
I was giving a pub quiz type quesstion the other day, which I managed to solve without the use of formulae/mathematics, but it got me thinking about how to solve it mathematically too.
Imagine a chain stretched between two posts, that then droops in the middle, and forms a natural parabola. What are the variables involved and what is the relationship that determines the curve?
I guess that it would mean calculating for all positions on the chain (using calculus?), in order to give a final curve, but this would require a basic starting formulae stating the relationship.
So variable would be, for any specific point on the chain:
Chain tension
Chain weight
Chain angle (tangent to curve)
Any others?
Any idea on the relationship?
looking forward to hearing your comments
thanks,
Martin
You are on the right track. Trouble is the shape is not a parabola, it is a catenary.
I cannot help you off the top of my head, but this type of analysis can be found in books on Partial Differential equations.
This site says it all:
http://teacher.sduhsd.k12.ca.us/abrown/Activities/Matching/answers/Catenary.htm
thanks guys, that's great!
Molydood
How so?
Hi,
'Solve' is perhaps the wrong word. I'll give you the problem then post the answer a little later if required:
two posts of 4 metre height support a chain of length 6 metres. The chain hangs 1 metre from the floor at its lowest point. How far apart are the posts?
Molydood said:
Hi,
AHA! THis is a brain teaser that does not require any knowledge of the catenary! (I've heard this one before, and I never got the chance to discover it for myself, so I won't give it away)
As Chi Meson said this has nothing to do with physics... but if the said chain hung 2 meters from the floor you couldn't solve it. :smile:
Yeah that brain teaser's pretty dumb... hehe.
- Warren
I can't believe that I did not see the solution instantly, had to think about it for a few minutes.
Nice brain teaser. I'll challenge my friends at school. I bet it'll drive them crazy!
So how is it solved without using the caternary formula?
Here's a hint: Draw it to scale.
cookiemonster
It's a tad hard to draw something that fits this equation
y = \frac{e^{ax} + e^{-ax}}{2a}
Besides, it aparently can be done without using that formula.
Heh, start with the posts. Then add in the minimum height off the ground. Calculate a distance or two, like how far the chain is drooping and how long the chain is. The rest comes pretty naturally.
cookiemonster
LOL, come on... Think man.
Consider the problem statement.
You are going to hate yourself when the solution pops into your head.
The only thing I can think of doing is breaking the length of the chain into little triangles then integrating it.
Let it all hang out!
You're working way too hard here, Shawn.
cookiemonster
Well what's the answer? I've asked a 3rd year chem honors student as well as a 2nd year mechanical engineer and neither of them can figure it out. I'm stumped as well.
That there is probably too big a hint...
cookiemonster
The chain is drooping 3 and it's 6 long. Those are both given in the question.
Yeah, now look at those two numbers for just one second.
cookiemonster
Think degenerate solution. :wink:
Yes I've seen that relationship but it still has to satisfy that equation.
y = \frac{e^0 + \frac{1}{e^0}}{2a}
y = \frac{1 + \frac{1}{1}}{2a}
y = \frac{2}{2a}
y = \frac{1}{a}
Nevermind, the 0 probably screws up the equation. 0's tend to do that.
Draw it as one triangle.
Shawn, did you ever get the answer? I'm interested to hear your reaction when you get it.
Martin
I'm more interested to see the look on his face when he gets it. :biggrin:
Consider approximating the chain's path with a triangle.
lol! Got it.
10K
