Calculating Potential Difference in a Uniform Electric Field
5 replies · 8K views
aliaze1
What is the potential difference between yi= -5cm and yf=5cm in the uniform electric field E = ( 20,000{ i } - 50,000 { j } )V/m?
∆V = V(sf) - V(si) = -∫ Es ds
with the limits of the integral being sf and si
I tried doing the integral, resulting in (E2)/2, and then multiplying proceding as so:
E= √ (200002 + 500002) = 53851.64807
(E2)/2 = 14500000 = x
x |0.05,-0.05 = -{x(0.05) - x(-0.05)} = -{2[x(0.05)]} = -1450000 = incorrect
any help?
thanks!
I think you're taking the integral as if it were E dE instead of ds (Compare with the case where if it were the integral of x dx, then the integral is x^2/2). E is a constant since it is "uniform", so you can treat it as a constant and pull it out of the integral. If you're only dealing with one dimension (along y), then the integral of E ds simplifies to E(Sf - Si).
aaahh lol nice...yea that was my mistake...lol whenever i see the integral sign i jump to conclusions without looking at the second part
thanks!
well actually...i tried that and it didn't work:
E = 53851.64807
Sf-Si = 0.05 - (-0.05) = 0.1
E * (Sf-Si) = 53851.64807 * 0.1 = 5385.164807 = Incorrect :(
Any help?
Thanks!
I have only one attempt left. I noticed that I didn't put the negative sign there, but the computer would tell me to 'check your signs' if this was a sign issue...so i assume it isn't
