Calculating Potential in a Conducting Sphere and Wire Configuration
  • Level: Graduate
  • Thread starter kyryk
    Potential
kyryk
I am trying to solve the following problem:
Consider the configuration of a conducting sphere of radius R held at potential V, and a conducting wire radially positioned with respect to the sphere with one end at R1>R, and the other end at R2>R1. What is the potential everywhere?
I chalked down a quick solution but I don't believe my answer. Any help would be appreciated!
This certainly seems like a homework-type question (even if it is not actual homework), so I think you should get a mod to move it to the homework subforums and post your attempt at a solution.
Not a homework question. As a matter of fact, never seen such type of E&M questions in standard books. I suspect that the wire presents some sort of singularity in the solution that is a bit tricky to handle, at least I can't see a standard solution applying here. However, if I'm wrong and there is a trivial solution, even better if this is indeed a homework question somewhere, I'd like a link or something of the sort.
Still seems like a homework-type question to me. In any case, you said in your first post that you "chalked down a quick solution" but aren't confident in your answer - why not post that solution (or the main points of it) so we can critique it?
