Engineering Calculating Power - Simple DC Circuit
The discussion revolves around calculating current and power in a simple DC circuit involving a constant current source and a voltage source. Participants clarify that the constant current source dictates the circuit's behavior, overriding other sources. Power calculations reveal that the voltage source generates 20W, while the current source absorbs -20W, leading to a total power balance of 0W, consistent with conservation of energy. Confusion arises about voltage across components, but it is resolved that the voltage across the resistor is 10V and the current source has no voltage across it. The conversation emphasizes the importance of understanding ideal sources and their implications in circuit analysis.
JosefMTD
http://puu.sh/7gYwk.png
Consider the circuit shown above. Find the current Ia flowing through the resistor and the power for each element in the circuit. Which elements are absorbing power?
P = V x I = I^2 x R = V^2 / R
I tried to find Ia first, the voltage source with the load produce 2A going the opposite direction from the current source, so I got Ia = 0A and makes all the power = 0W
Is this correct?
Hi JosefMTD! http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Is that a constant current source in your circuit? What do you understand is the behaviour of a "constant current source"?
I think it's a constant current source.
It's always of the same value and stays on the same direction, does it override all other current source though? I have no idea, I may have missed this during class :-\
Yes, the constant current source always wins! Everything else must accommodate the dictates of a constant current source.
So you never arrange two where there would be conflict, or there will be fireworks!
Well, thank you very much. I must have fail to listen carefully during class while this happens :P
But then,
Power on resistance = (2A)(2A)(5Ω) = (10 V)(10 V)/(5Ω) = 20 W
Power on voltage source = (10V)(2A) = 20 W
Power on current source = (-10V)(2A) = -20 W
It adds up to 20W, but according to conservation of energy: ∑p = 0 for a closed circuit. My "gut" feeling says the voltage source should have 0 W power, don't know why. So anyways, where did I do wrong :o?
Why did you decide to throw in that negative sign when calculating the current source's power output?
Because of the active sign convention.
I did it like I did on the previous question:
http://puu.sh/7h4PK.png
By the way, can you offer an explaintion of why you believe the current source has a voltage of 10v?
I'm taking reference from the previous question which is shown up there, dunno, I figured it should be the same, or it shouldn't? :o
Well this one has a resistor in the circuit, so that makes it a bit different.
If you take the voltage at the bottom of the voltage source as V0 = 0v, then work around the circuit and calculate the voltage at each node.
At the node bewtween the voltage source and the resistor, V1 = ?
At the node between the resistor and the current source, V2=?
At the node between the current source and the voltage source V3=?
Oh, I see.
V1 = 10V
V2 according to KCL
∑I = 0, V2-V1/5Ω - 2A = 0
V2 - 10V = 10V, V2 = 20V
V3 according to KVL
V2-V3 = V3-V0
20V = 2V3
V3 = 10V
Damn, I'm confused :confused:
How many volts across the constant voltage source?
How many volts across the resistor itself?
I guess that is confusing, when you put it that way.
I thought you would have recognized the following:
V3 = V0 = 0 since they are the same node.
You really do not have to do a KVL calculation on it.
With KVL you can do:
V2-V3 = V2-V0 ie summation of voltages going left from V2 = going right from V2
V2=V2
1. 10V
2. With using KCL on the node between current source and resistor, I got 10 V across the resistor
I don't know why, but I never had problems in solving these kinds of problems, I think I forgot all of the basics because I had a too long vacation :P
OMG.
@256bits
V2 = 0 V
(V1 - V2)/5 ohm = 2A [KCL]
(10 V - V2) = 10 V
V2 = 10 V - 10 V = 0 V
No voltage across current source.
Do we use the generator-load convention to make the 20 W on voltage source to be generating power not absorbing because it's positive?
Thank you guys so much :D
Finally, I think I'm getting to know the basics again XD
Really? I think maybe you still have a little work to do on the basics.
Also, as nascentoxygen alluded to in post #4, if this were a real world situation and the voltage source was a battery, it would most likely explode. Do you understand why?
Because the current generated from the constant voltage source would always make it 2A to the opposite side of constant current source. Ka boom.
JosefMTD said:
OMG.
@256bits
V2 = 0 V
(10 V - V2) = 10 V
You already had across the voltage-source 10v, and across the resistor 10v.
so how do you now get 0v?
Try,
(V2- V1)/5 ohm = 2A [KCL]
in the direction of the current.
OH OH OH OH OH LOL
LOL
Yeah, I messed up XD
I realized where I did wrong XD
Thank you guys for bearing with me ;D
(V2 - V1)/5 ohm = 2 A
V2 - V1 = 10 V
V2 = 20 V
V3 = 0 V
Voltage across the constant current source = 20 V
with the active sign convention, the power on constant current source is - 40 W.
with the passive sign convention, the power on constant voltage source is 20 W
the power on resistor is 20 W
Summation of all the power in components is 0. I'm a bit sure that this one is right, now ;D
OK. That's fine.
Absolutely wrong. Ideal sources always have exactly what they say they have. You cannot HAVE ideal sources in the configuration you show.
My question was why would a real-world BATTERY explode. You seemed to think it would be the current source that would explode.
Also, you did not answer my question about the voltage across the current source. You really DO need to go back and restudy the basics.
Not quite. A battery is recharged in this manner, for example.
An ideal voltage source will happily source or sink any amount of current in order to maintain its fixed potential difference. Similarly, an ideal current source will produce any potential difference (positive or negative) required in order to maintain its fixed current.
Well, yeah, but normally at a trickle charge, not 2 amps !
Right. I was wrong about the circuit having a contradiction in the ideal case, since the 10v source will just let -2 amps flow through it. Thanks for that correction.
I do agree I need to read the basics again.
"OK. That's fine"
I'll assume that equations I brought up is correct then. Thank you all for helping me to solve this problem. ;D
