Calculating pressure / energy difference confusion
1 reply · 2K views
Farang
The electron density per area, ##N## for a gas layer of thickness 10 cm can be determined
$$n = k \times p \times 2.47 \times 10^{19}$$
For each adjacent sets of pressure data using Matlab, calculate the average energy in keV, the pressure difference in hPa, the energy difference in keV and then evaluate ##-\frac{\Delta E}{\Delta p}## in keV/hPa. Plot this as a function of the average energy, along with the theoretical energy loss, that can be calculated using analysis based on equation
$$-\frac{dE}{dx}=\frac{4\pi n Z^{2}}{m_{e}v^{2}} \left ( \frac{e^{2}}{4 \pi \epsilon_{0}} \right )^{2} ln\left ( \frac{2m_{e}v^{2}}{I} \right )$$
Using ##\mu = \frac{m_{e}}{m_{He}} = \frac{511 keV}{3.727 GeV} = 1.371 \times 10^{-4}## and ##Z = 2##.
$$-\frac{dE}{dx}=\frac{2\pi Z^{2}}{\mu E} \frac{N(p)}{p} \left ( \frac{e^{2}}{4 \pi \epsilon_{0}^{2}} \right )^{2} ln\left ( \mu \frac{4E}{I} \right )$$
$$-\frac{dE}{dp}=\frac{k}{E} \times 2.41\times10^{-29} \frac{J^{2}}{hPa} \times ln\left ( 5.848\times10^{-4} \frac{E}{I} \right )$$
which can be written in an equivalent form
$$-\frac{dE}{dp}=\frac{k}{E} \times 940 \frac{keV^{2}}{hPa} \times ln\left ( 5.848\times10^{-4} \frac{E}{I} \right )$$
which is suitable for the creation of a theoretical curve that can be compared to the experimental data by plotting them on the same axes.
You need to present your data in the form of a Bragg plot, which shows both
the energy and differential energy loss as a function of pressure, as shown by the exemplar data in figure 3.2
All above...
Following the lab script has always been the most difficult part of the course for me for some reason. Often I can't figure out what is that I am supposed to do or even what I've just done. Perhaps someone here will be able to make sense of this...
So far I have 2 tables(one for Helium and one for air) with 4 rows each(Max # of impulses, Energy(keV), Average energy(keV) and Pressure(mbar)).
How / why / between what pressure difference does it want me to calculate?
Ok I think I'm getting there, painfully slowly... I need to plot alpha energy and energy loss as a function of pressure. What a way to spend a Saturday night...
