Calculating Principle Moments of Inertia
The discussion focuses on calculating the principal moments of inertia along principal axes using given moments of inertia (J1 = 18 kgm², J2 = 15 kgm², J3 = 6 kgm²) and their corresponding directional vectors. The participants clarify that the principal moments of inertia act along the principal axes and that the inertia tensor has non-zero values only on the main diagonal when using these axes. A method for transforming the inertia tensor to a new coordinate system defined by the relationships -z=x, x=y, and y=-z is also discussed, emphasizing the use of a 3D rotation matrix for this transformation.
  • Understanding of principal moments of inertia
  • Familiarity with inertia tensors and their properties
  • Knowledge of 3D rotation matrices
  • Basic grasp of Euler angles and coordinate transformations
  • Study the derivation of the inertia tensor and its diagonalization process
  • Learn about 3D rotation matrices and their applications in mechanics
  • Explore coordinate transformations for moments of inertia in detail
  • Review the relationship between Euler angles and rotational transformations
Mechanical engineers, physics students, and anyone involved in dynamics and rotational mechanics will benefit from this discussion, particularly those working with inertia calculations and coordinate transformations.
bugatti79
Hi Folks,
Is it possible to calculate the principle moments of inertia acting along the principle axes of inertia given the moments of inertia and their directional vectors. Ie , I have the following information
Moments of inertia ##J_1, J_2,J_3=18kgm2,15kgm2,6kgm2##
and the directional vectors
##\begin{bmatrix}J_{1x}& J_{1y}&J_{1z} \\ J_{2x} &J_{2y} &J_{2z} \\ J_{3x}&J_{3y} & J_{3z}\end{bmatrix}=\begin{bmatrix}0.4& 0.7&-0.2 \\ -0.8 &.1 &0.8 \\ 0.2&0.8 & 0.7\end{bmatrix}##
I also have the euler angles but I am not sure if there is some relationship between these and the directional vectors or indeed if I need them.
Any information will be appreciated.
Regards
bugatti79 said:
Hi Folks,
Regards
Here, we are talking about 'principal' axes and 'principal' moments of inertia.
You are using J for moments of inertia and direction cosines, so it's hard to know what information you have. There is a way to find the principal axes given a matrix of inertia values about some arbitrary coordinate system:
http://ocw.mit.edu/courses/aeronaut...fall-2009/lecture-notes/MIT16_07F09_Lec26.pdf
If you have only J1, J2, and J3, these may already be the principal moments of inertia.
Hi SteamKing,
Thanks for the reply. Actually, you are right. The J values are actually the principle moments of inertia but don't they act along the principle axes and not some set of direction cosines?
What I really want to do is calculate the moments of inertia for a new xyz coordinate system where the old and new coordinate system are related respectively by
-z=x, x=y and y=-z
So is it just a matter of rotating in steps of 90 deg and not consider the direction cosines given above...? Ie, what is the rotation matrix?
bugatti79 said:
Hi SteamKing,
The principal moments of inertia are found only about the principal axes. The inertia tensor has non-zero values only on the main diagonal when using the principal axes.
-z=x, x=y and y=-z
There are coordinate transformations for mass moments of inertia similar to those for area moments of inertia, which, of course, are defined only for 2-D planes.
The 3-D coordinate rotation matrix can be set up like in this article:
http://en.wikipedia.org/wiki/Rotation_matrix
To calculate the moment of inertia of a body about an arbitrary axis, this article is recommended:
http://www.eng.auburn.edu/~marghitu/MECH2110/C_4.pdf
Eq. 4.8 on page 4 and the derivation above are what you are looking for, I believe.
The problem I have understanding is that I have the 3 J values which are the principle moments and so act along the principle axes as we have agreed. And we know the relationship between the old and new is just
##-z=x, x=y## and ##y=-z ##
So I can just use the 3D rotation matrix given in that wiki link you provided and rotate in steps of 90deg. I don't actually need the direction cosines or the euler angles, right?
There are 2 steps.
The first step is to use the euler angles to translate back to the original coordinate system then the second step is to translate this new tensor into the desired new co ordinate system. It works. Thanks
13K
10K
