Calculating q, w, H, and U for an Ideal Gas at 25°C and 100kPa
  • Thread starter Thread starter chocolatepie
The discussion revolves around calculating work (w), heat (q), change in internal energy (ΔU), and change in enthalpy (ΔH) for an ideal gas undergoing isothermal expansion from 100 kPa to 5 kPa at 25°C. Participants clarify that for an isothermal process, the change in internal energy (ΔU) is zero, and work can be calculated using the formula Wrev = nRT ln(P2/P1), with n set to 1 mol for per mol calculations. There is confusion regarding the appropriate formulas for ΔH, with participants noting that ΔH = ΔU + pΔV is not applicable since the process does not occur at constant pressure. The discussion emphasizes the need to use the correct equations based on the conditions of the process, particularly for ideal gases. Overall, the conversation highlights the importance of understanding thermodynamic principles and the specific conditions of the problem.
chocolatepie
An ideal gas at 25degree celsius and 100kPa is allowed to expand reversibly and isothermally to 5kPa. Calculate..
1) w per mol (J/mol)
2) q per mol (J/mol)
3) change in molar internal energy U (J/mol)
4) change in molar enthalpy H (J/mol)
ΔU = q + w
= q - pextΔV
ΔH = ΔU +p ΔV
= ΔU + ΔngasRT
PV=nRT
Um(T)=3/2RT
I absolutely have no idea how to do this question. Any direction would be greatly appreciated.
Welcome to the forum.
Hint:
A reversible isothermal process is a polytropic process where PV^n = constant. What is n for this kind of process?
I am thinking this question should include a molar volume? (molar volume = V/n, which changes the ideal gas law as P(molar volume) = RT?)
n is constant for this kind of process? but that sounds weird.. sorry I am lost..
Also, since it is an isothermal process, would molar U be 0?
Welcome to PF, chocolatepie! :smile:
An isothermal process is one in which T is constant.
So molar U will not be zero, but constant.
In other words: ΔU=0.
With constant T=To, you get for one mole: PV=RTo.
To calculate w you need to integrate dw=-PdV.
Do you know how to do that?
I assuming we need to use Wrev= nRT ln (P2/P1) to solve.
However, we were not given n value...?
PS. And thanks everyone for the warm welcome to PF :D
Yep. That will work.
n is the number of moles.
The question asks to calculate "per mol".
This means you should calculate using n=1 mol.
You're welcome! :wink:
oh, OK!
And for part (d) where I need to calculate for the change of molar enthalpy, should I use ΔH = qp to solve? or ΔH = ΔU + pΔV?
I just don't know when to use each formula..
chocolatepie said:
oh, OK!
Actually, neither formula.
Both have conditions attached.
ΔH = qp only holds in an isobaric process.
ΔH = ΔU + pΔV also only holds in an isobaric process (is this really the formula you have?)
What else do you have for ΔH?
The note at the bottom of the question says that the expansion does not occur at constant pressure. Thus, iti s not OK to use ΔH = ΔU + pΔV.
I am not sure why the note says "constant pressure" when the question itself says "constant temperature" :-O
I have one that includes heat capacity..? H=CpT (subscript p = const P)
But I don't have the heat capacity given in the question, so I didn't use it.
In your relevant equations you have:
ΔH = ΔU + ΔngasRT
(Works only for ideal gasses.)
What about that one?Btw, Cp=Cv+R for ideal gasses.
And ΔH = ΔU + Δ(PV) is true in general.
Aha, now I got it. Yes there was a formula on my note.
Thank you so much!
See you! :smile:
