Calculating Ratio of Electrical Current to Light Speed: A Challenge!
The discussion revolves around calculating the ratio of electrical current speed to light speed for a wire resonating at a specific frequency. The wire, treated as a closed tube, has a fundamental frequency formula of f = v/2L, leading to a calculated speed of 222,200,000 m/s. The ratio of this speed to the speed of light (approximately 3E8 m/s) is found to be 0.074. Participants clarify the correct application of resonance formulas for closed-ended tubes and emphasize the importance of understanding nodes and antinodes in wave behavior. The final conclusion confirms the correct speed and ratio calculations based on the fundamental frequency for a closed cylinder.
woaini
If a 0.505m long wire is excited into its lowest electrical resonance by a 2.2E7 Hz electrical oscillator, what is the ratio of the speed of the electrical current to that of light? Assume that the wire is like a tube with both ends closed.
f=2.2E7
L=0.505
v=?
f=nv/2L
f=v/λ
How do I solve this problem if I do not have λ or n? How would the equations work?
Hint: How would you find λ if this was a problem involving sound waves in an organ pipe? You would do a drawing showing a standing wave with nodes and antinodes then calculate the wavelength.
How do I know how any nodes and antinodes to draw?
The problem states "lowest electrical resonance"
Does that mean n=1?
It says the fundamental frequency for a closed cylinder is f=v/4L
Therefore the speed I determine using the formula is...
v= f*4L = 2.2E7 * 4 *0.505 = 444400000 m/s
And the ratio of it to the speed of light is:
444400000 m/s / 3E8 m/s = 0.148
Does this look correct?
I think that's the formulae for a cylinder with one end open and one closed.
So how do I determine the formula for something closed on both ends?
"Closed ends on a tube form a node..."
Draw it?
If you looked at the link I gave earlier it shows a drawing for one end open and one end closed. You can see how the formula is derived from that drawing. Do a new drawing with both ends closed and apply same ideas.
Oh I see, the formula should be f=v/2L
22220000m/s is the new speed I get?
Remember they ask for a ratio.
Alright makes sense now.
