Calculating ratio of voltage help
  • Thread starter Thread starter joe007
    Ratio Voltage
The discussion revolves around calculating the voltage across a resistor and a capacitor in a circuit with a given frequency of 10 Hz. The components under consideration are a 4.7 kΩ resistor and a 100 nF capacitor, with a 10V power source mentioned.
  • Mixed
  • Participants explore the use of impedance in calculating voltage across components in series. There are attempts to apply formulas for voltage ratios and impedance, but some participants express uncertainty about the correctness of their calculations and the need for additional information about the circuit.
Participants are actively discussing the calculations needed for the voltage across each component. Some guidance has been offered regarding the correct approach to calculating total impedance, and there is an ongoing exploration of how to combine the impedances of the resistor and capacitor.
There is a noted lack of information regarding the circuit configuration and the power source specifics, which participants indicate may be necessary for a complete analysis.
joe007
At the given 10 Hz frequency calculate the magnitude of the voltage across a:
(1)4.7kohm resistor
(2)100nF capacitor
Vr/v=R/z=R/sqrtR^2+(1/wC)
Vc/v=(1/wC)/z=(1/wC)//sqrtR^2+(1/wC)
(1)4.7/sqrt(4.7^2+2*PI*4.7^2) ------i am not sure if this correct
and for part 2
(2)1/(2*PI*100*10^-9)/sqrt()
not sure of what value to use for the R
There should be more information. What information was given about the power source? What circuit was described?
oh it had 10V power source
i think i have to calculate the voltage across each component as they are in series but not sure how to use impedance on this question
It appears that you are using as the formula for the total impedance:
z=sqrtR^2+(1/wC)
You have not derived this correctly.
You are aware that the total impedance is the sum of the impedance of R + the impedance of C. But because these individual impedances are at right angles to each other, you must add them like vectors at right angles to each other.
Complete this: the impedance of a capacitor of 100nF at 10Hz =
ok z=1/2PI*10*100*10^-9 then
Consider using parentheses to clarify the mathematical operator precedence in your expressions. The X2 and X2 icons in the post composition header let's you create superscripts and subscripts, too. Thus:
Zc = 1/(2*pi*10*100*10-9)
Now, basing your calculations on a right-angled triangle, add the two series impedances.
  • · Replies 17 ·
