Calculating Required Surface Charge Density for a Cylinder
8 replies · 3K views · last reply
suspenc3
A long, straight wire has a linear charge density of magnitude 3.6nC/m. The wire is to be enclosed by a thin, no-conducting cylinder of ouside radius 1.5cm, coaxil witht he wire. The cylinder is to have positive charge on its outside surface with a surface charge density [tex]\sigma[/tex] such that the net external electric field is zero. Calculate the required [tex]\sigma[/tex].
[tex]E=\frac{\lambda}{2\pi \epsilon_0 r}[/tex]
The electric field can be found, but then how do I go about finding the required [tex]\sigma[/tex] value?
The wire has obviously negative charge. Hasn't it?
Apply Gauss's Law, to a gaussian surface, I recommend you to use another cylinder, and put the condition that:
[tex]\oint E\cdot dS=0[/tex]
The total field is zero right? It is due to a superposition of the field from the wire and the field from the cylindrical shell.
So Do I just find an electric field for the gaussian surface that when summed with the electric field already found wll equal zero?
Since the total electrical field is 0, and I can find [tex]E=\frac{\lambda}{2\pi \epsilon_0 r}[/tex], can't I just find [tex]E=\frac{\sigma}{\epsilon_0}[/tex]
and then [tex]\frac{\lambda}{2\pi \epsilon_0 r} = -\frac{\sigma}{\epsilon_0}[/tex] and then solve for [tex]\sigma[/tex]
Sorry if this make no sense, I don't really understand this stuff.
