Calculating Spring Constant and Mechanical Energy
1 reply · 2K views
xCharade
When a .5kg mass is suspended from a spring, the spring stretches 4cm. The mass is then displaced 2cm from its equilibrium position and released.
(a) What is the spring constant? (b) What is the mechanical energy of the mass? (c) What is the speed of the mass as it passes through its equilibrium position going down and going up?
F=kx (k is spring constant)
W= .5(k)x2
KE= .5mv2
For part A I used F=kx:
mg=kx
(.5kg)(9.8m/s2) = k (.04m)
k= 122.5N/m
For part B I used W= .5kx2:
W= .5(122.5N/m)(.02m)2
W= .025J
For part C I used KE = .5mv2
.025J = .5(.5kg)v2
v= .32m/s
I just need to make sure that I'm on the right track with this problem. I can get confused as to when to use .04m and .02 and generally with using formulas.
How much gravitational energy is there when the mass is displaced 2cm = 0.002m from its equilibrium position? Hint: The spring originally stretched 0.0004m when the mass was suspended.
